Fresh install of balenaOS 2.98.33 with Balena Sound installed. This is on a first revision Rasperry Pi 4b. What info can I give you to help me troubleshoot?
Using the headphone jack, tried playing both via Spotify and bluetooth. Verified speakers work.
Hi
Can you see anything out of the ordinary in the logs? You can start with sharing them
Here’s the current log:
balena-sound_dark-car-04.07.22_08_51_40_(-0400).txt (76.4 KB)
Not sure what I’m looking for.
This sounds like it might be a similar issue to this one: No sound output with balenaOS 64 bit on Raspberry Pi 3 · Issue #82 · balenalabs/balena-sound · GitHub. Could you try removing the vc4-kms-v3d overlay from the device configuration and then reboot?
Saw that series of threads. Tried, and no luck
