I am having trouble copying an image to my microSD card using the “Flash from URL” feature. Downloading and decompressing the file is correct, saving and verification is 100% error-free. But when verification is complete, the message “Flash Failed!” Is displayed and the error code “EVALIDATION” appears at the end of the console log. Below are the last relevant lines of the console log. I noticed the problem both on the newest version of balenaEtcher (1.7.7) and several earlier versions (1.5.x). BalenaEtcher runs as an administrator. I use several SanDisk 16GB Class 10 microSD cards for write tests, but each has the same problem. All tests were run on Windows 10 Pro 64-bit. I looked through a lot of Forum posts and tried to apply every rational idea, but to no avail.
Do any of you know how to solve this problem?
Regards,
Maciex
Last lines of console log:
gui.js:35 Verifying 1 device, 99% at 16.70 MB/s (total 16.70 MB/s) eta in 1s with 0 failed devices
gui.js:46 Fri Mar 11 2022 09:02:19 GMT+0100 (czas środkowoeuropejski standardowy) Validation error ({“image”:{“size”:15931522560,“compressedSize”:3318785699,“hasMBR”:true,“path”:“https://www.eutonomy.com/download/eulink/firmware/latest_euLINK_firmware.img.gz",“partitions”:[{“offset”:1048576,“size”:268435456,“type”:12,“index”:1},{“offset”:269484032,“size”:15662038528,“type”:131,“index”:2}],“isCompressed”:true,“name”:“latest_euLINK_firmware.img”,“isSizeEstimated”:true,“extension”:“gz”},“drives”:[{“size”:15931539456,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:“F:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“F:\”}],“description”:"Generic- SD/MMC USB Device”,“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“6153a00d-9e24-482c-a355-062f99f6cb97”,“flashInstanceUuid”:“6153a00d-9e24-482c-a355-062f99f6cb97”,“sample”:0.1,“applicationSessionUuid”:“c6c320e6-29c8-4150-8b72-534098384a9c”,“flashingWorkflowUuid”:“6ee03690-f84a-497f-b58e-b435431982d8”})
gui.js:35 Verifying 1 device, 100% at 18.10 MB/s (total 18.10 MB/s) eta in 0s with 0 failed devices
gui.js:46 Finish: 15931539456
gui.js:46 Terminating IPC server
gui.js:46 Flash results Object
gui.js:46 Fri Mar 11 2022 09:02:23 GMT+0100 (czas środkowoeuropejski standardowy) Done ({“image”:{“size”:15931522560,“compressedSize”:3318785699,“hasMBR”:true,“path”:“https://www.eutonomy.com/download/eulink/firmware/latest_euLINK_firmware.img.gz",“partitions”:[{“offset”:1048576,“size”:268435456,“type”:12,“index”:1},{“offset”:269484032,“size”:15662038528,“type”:131,“index”:2}],“isCompressed”:true,“name”:“latest_euLINK_firmware.img”,“isSizeEstimated”:true,“extension”:“gz”},“drives”:[{“size”:15931539456,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:“F:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“F:\”}],“description”:"Generic- SD/MMC USB Device”,“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“6153a00d-9e24-482c-a355-062f99f6cb97”,“status”:“finished”,“flashInstanceUuid”:“6153a00d-9e24-482c-a355-062f99f6cb97”,“errors”:[{“name”:“Error”,“description”:“Generic- SD/MMC USB Device”,“code”:“EVALIDATION”,“device”:"\\.\PhysicalDrive1"}],“devices”:{“failed”:1,“successful”:0},“bytesWritten”:15931539456,“sourceMetadata”:{“isCompressed”:true,“name”:“latest_euLINK_firmware.img”,“size”:15931539456,“compressedSize”:3318785699,“isSizeEstimated”:false},“sample”:0.1,“applicationSessionUuid”:“c6c320e6-29c8-4150-8b72-534098384a9c”,“flashingWorkflowUuid”:“6ee03690-f84a-497f-b58e-b435431982d8”})
gui.js:46 Fri Mar 11 2022 09:02:24 GMT+0100 (czas środkowoeuropejski standardowy) SafeWebview loaded ({“event”:{“id”:18,“url”:“https://www.balena.io/etcher/success-banner/?borderTop=false&darkBackground=true&etcher-version=1.7.7&api-version=2&optOutAnalytics=true",“method”:“GET”,“timestamp”:1646985744754.729,“resourceType”:“mainFrame”,“ip”:“18.159.128.50”,“fromCache”:false,“statusLine”:"HTTP/1.1 200”,“statusCode”:200,“responseHeaders”:{“age”:[“64556”],“cache-control”:[“public, max-age=0, must-revalidate”],“content-encoding”:[“br”],“content-length”:[“6201”],“content-type”:[“text/html; charset=UTF-8”],“date”:[“Thu, 10 Mar 2022 14:06:29 GMT”],“etag”:["“97c38960337dd1168c0dafb01646d061-ssl-df”"],“link”:["</webpack-runtime-089d98f9359977565314.js>; rel=preload; as=script, </styles-c4fa86dfd4ad05097eee.js>; rel=preload; as=script, </framework-004503f2df4bb68d43f8.js>; rel=preload; as=script, </50c25a04-a68e3217d6ce65727bd7.js>; rel=preload; as=script, </73ad3401-ecb0d3613fde52e78ca5.js>; rel=preload; as=script, </532a2f07-f1ad28da1825cfcce2c7.js>; rel=preload; as=script, </app-d3f2c796bc2e57a8750f.js>; rel=preload; as=script, </c943faba-f859f80ceb7f4f7eab31.js>; rel=preload; as=script, </af13d906-36fdbc23fc7dd2f2b2e7.js>; rel=preload; as=script, </ec1189df-4ae9e03f4545d4f1d61b.js>; rel=preload; as=script, </a9a7754c-29508ff4045f1f93a5f6.js>; rel=preload; as=script, </commons-cea6bfcc846ea7ff6166.js>; rel=preload; as=script, </c974efff6ac245e04f4a26711b42db767846e0e5-b1b7091203b51af325ff.js>; rel=preload; as=script, </component—src-pages-etcher-success-banner-js-98ac1a1084e1d2a478fa.js>; rel=preload; as=script, </page-data/app-data.json>; rel=preload; as=fetch; crossorigin, </page-data/etcher/success-banner/page-data.json>; rel=preload; as=fetch; crossorigin"],“referrer-policy”:[“strict-origin-when-cross-origin”],“server”:[“Netlify”],“strict-transport-security”:[“max-age=31536000”],“vary”:[“Accept-Encoding”],“x-content-type-options”:[“nosniff”],“x-frame-options”:[“DENY”],“x-nf-request-id”:[“01FXW005ABBJ9068HWGJM4Z07H”],“x-xss-protection”:[“1; mode=block”]},“referrer”:"",“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“c6c320e6-29c8-4150-8b72-534098384a9c”,“flashingWorkflowUuid”:“6ee03690-f84a-497f-b58e-b435431982d8”})
gui.js:46 Message from SafeWebview: Error: Not supported
