Hi Guys, I am facing the same issue. After downloading Tails and Echter I get the an error message “…something went wrong…User did not get grant persmission…” while flashing on usb.
Im am using
Windows 10 Home
Echter 1.5.113 (also tried the portable version and to run it as admin)
Tails vor USB
Many thanks
J
Here is the error message I get:
index.css:1 Failed to load resource: net::ERR_FILE_NOT_FOUND
electron/js2c/renderer_init.js:13 (electron) The remote module is deprecated. Use GitHub - electron/remote: Bridge JavaScript objects from the main process to the renderer process in Electron. instead.
log @ electron/js2c/renderer_init.js:13
gui.js:364 _____ _ _
| | | | | | ___ _ __
| || / | ’ \ / _ \ '|
_/ ____|| ||___||
Interested in joining the Etcher team?
Drop us a line at join+etcher@balena.io
Version = 1.7.8, Type = portable
gui.js:46 Wed Oct 12 2022 19:21:38 GMT+0200 (Mitteleuropäische Sommerzeit) Application start ({“packageType”:“portable”,“version”:“1.7.8”,“sample”:0.1,“applicationSessionUuid”:“e90386f1-dbf6-4554-9dea-04ae7bb82ca2”,“flashingWorkflowUuid”:“170574cf-03fc-48ce-aaad-53fd7db42e09”})
gui.js:46 [Axios v1.7.8] Transitional option ‘clarifyTimeoutError’ has been deprecated since v1.0.0 and will be removed in the near future
console. @ gui.js:46
gui.js:46 [Axios v1.7.8] Transitional option ‘forcedJSONParsing’ has been deprecated since v1.0.0 and will be removed in the near future
gui.js:46 [Axios v1.7.8] Transitional option ‘silentJSONParsing’ has been deprecated since v1.0.0 and will be removed in the near future
gui.js:46 Wed Oct 12 2022 19:22:04 GMT+0200 (Mitteleuropäische Sommerzeit) Open image selector ({“sample”:0.1,“applicationSessionUuid”:“e90386f1-dbf6-4554-9dea-04ae7bb82ca2”,“flashingWorkflowUuid”:“170574cf-03fc-48ce-aaad-53fd7db42e09”})
gui.js:46 Wed Oct 12 2022 19:22:09 GMT+0200 (Mitteleuropäische Sommerzeit) Select image ({“image”:{“size”:1309671424,“name”:“tails-amd64-5.4.img”,“hasMBR”:true,“partitions”:[{“offset”:1048576,“size”:1307574272,“type”:“C12A7328-F81F-11D2-BA4B-00A0C93EC93B”,“guid”:“34BF027A-8001-4B93-8243-1F9D3DCE7DE7”,“name”:“Tails”,“index”:1}],“extension”:“img”,“path”:“C:\Users\Familie\Documents\Tails\tails-amd64-5.4.img”,“logo”:false,“blockMap”:false},“sample”:0.1,“applicationSessionUuid”:“e90386f1-dbf6-4554-9dea-04ae7bb82ca2”,“flashingWorkflowUuid”:“170574cf-03fc-48ce-aaad-53fd7db42e09”})
gui.js:46 Wed Oct 12 2022 19:22:17 GMT+0200 (Mitteleuropäische Sommerzeit) Flash ({“image”:{“size”:1309671424,“name”:“tails-amd64-5.4.img”,“hasMBR”:true,“partitions”:[{“offset”:1048576,“size”:1307574272,“type”:“C12A7328-F81F-11D2-BA4B-00A0C93EC93B”,“guid”:“34BF027A-8001-4B93-8243-1F9D3DCE7DE7”,“name”:“Tails”,“index”:1}],“extension”:“img”,“path”:“C:\Users\Familie\Documents\Tails\tails-amd64-5.4.img”},“drives”:[{“size”:61530439680,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:“\\.\PhysicalDrive1”,“error”:null,“isReadOnly”:false,“displayName”:“E:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:“\\.\PhysicalDrive1”,“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“E:\”}],“description”:" USB SanDisk 3.2Gen1 USB Device",“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“bed906e7-3de3-486f-bdec-f224a031cc42”,“status”:“started”,“flashInstanceUuid”:“bed906e7-3de3-486f-bdec-f224a031cc42”,“sample”:0.1,“applicationSessionUuid”:“e90386f1-dbf6-4554-9dea-04ae7bb82ca2”,“flashingWorkflowUuid”:“170574cf-03fc-48ce-aaad-53fd7db42e09”})
gui.js:46 Elevating command: C:\Users\Familie\AppData\Local\Temp\26ZDwweoEftoYLfXXExMqtMd7tA\balenaEtcher.exe C:\Users\Familie\AppData\Local\Temp\26ZDwweoEftoYLfXXExMqtMd7tA\resources\app\generated\child-writer.js
gui.js:35 0 devices, 0% at 0.00 MB/s (total 0.00 MB/s) with 0 failed devices
gui.js:46 Terminating IPC server
gui.js:46 Flash results {}
gui.js:46 Wed Oct 12 2022 19:22:18 GMT+0200 (Mitteleuropäische Sommerzeit) Write failed ({“image”:{“size”:1309671424,“name”:“tails-amd64-5.4.img”,“hasMBR”:true,“partitions”:[{“offset”:1048576,“size”:1307574272,“type”:“C12A7328-F81F-11D2-BA4B-00A0C93EC93B”,“guid”:“34BF027A-8001-4B93-8243-1F9D3DCE7DE7”,“name”:“Tails”,“index”:1}],“extension”:“img”,“path”:“C:\Users\Familie\Documents\Tails\tails-amd64-5.4.img”},“drives”:[{“size”:61530439680,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:“\\.\PhysicalDrive1”,“error”:null,“isReadOnly”:false,“displayName”:“E:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:“\\.\PhysicalDrive1”,“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“E:\”}],“description”:" USB SanDisk 3.2Gen1 USB Device",“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“bed906e7-3de3-486f-bdec-f224a031cc42”,“status”:“failed”,“flashInstanceUuid”:“bed906e7-3de3-486f-bdec-f224a031cc42”,“error”:{},“sample”:0.1,“applicationSessionUuid”:“e90386f1-dbf6-4554-9dea-04ae7bb82ca2”,“flashingWorkflowUuid”:“170574cf-03fc-48ce-aaad-53fd7db42e09”})
gui.js:46 {“stack”:“Error: User did not grant permission.\n at file:///C%3A/Users/Familie/AppData/Local/Temp/26ZDwweoEftoYLfXXExMqtMd7tA/resources/app/generated/gui.js:46:702552\n at ChildProcess.exithandler (child_process.js:324:5)\n at ChildProcess.emit (events.js:315:20)\n at maybeClose (internal/child_process.js:1048:16)\n at Process.ChildProcess._handle.onexit (internal/child_process.js:288:5)”,“message”:“User did not grant permission.”,“image”:“tails-amd64-5.4.img”}
