When hovering the mouse over 1 failed device the error provided is “\.\PhysicalDrive1:UNKNOWN:unknown error, write”
The logs when the error happened:
Mon Feb 24 2020 16:36:47 GMT-0800 (Pacific Standard Time) Drive unplugged ({“applicationSessionUuid”:“dd262401-421d-493b-9b2b-d693554455ea”,“flashingWorkflowUuid”:“c7eecd4a-0bac-494d-816b-dd7c68be220b”,“flashInstanceUuid”:“eaecf56f-5f55-44fd-8acf-92ee81ea6a39”,“image”:“C:\Users\Alpha\Downloads\LL_2020_2_RELEASE.zip”,“drives”:[{“size”:3909091328,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:"\\.\PhysicalDrive1",“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“1.0”,“icon”:“raspberrypi”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:,“description”:“Compute Module”,“isUAS”:false}],“driveCount”:1,“uuid”:“eaecf56f-5f55-44fd-8acf-92ee81ea6a39”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“trim”:false,“sample”:0.1})
C:\Users\Alpha\AppData\Local\Temp\1UvXH4mUtGaXW8AKaReztrB3uou\resources\app.asar\node_modules\resin-corvus\src\resin-corvus.js:39 Mon Feb 24 2020 16:36:47 GMT-0800 (Pacific Standard Time) Flashing 0 devices, 2% at 0.4 MB/s (total 0 MB/s) eta in 9102.34375s with 1 failed devices
image-writer.js:141 Finish: 91291648
image-writer.js:229 Flash results Object
C:\Users\Alpha\AppData\Local\Temp\1UvXH4mUtGaXW8AKaReztrB3uou\resources\app.asar\node_modules\resin-corvus\src\resin-corvus.js:39 Mon Feb 24 2020 16:36:49 GMT-0800 (Pacific Standard Time) Done ({“errors”:[{“name”:“Error”,“code”:“EUNPLUGGED”,“syscall”:“write”,“errno”:-4094,“device”:"\\.\PhysicalDrive1"}],“devices”:{“failed”:1,“successful”:0},“status”:“started”,“image”:“C:\Users\Alpha\Downloads\LL_2020_2_RELEASE.zip”,“drives”:[{“size”:3909091328,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:"\\.\PhysicalDrive1",“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“1.0”,“icon”:“raspberrypi”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:,“description”:“Compute Module”,“isUAS”:false}],“driveCount”:1,“uuid”:“eaecf56f-5f55-44fd-8acf-92ee81ea6a39”,“flashInstanceUuid”:“eaecf56f-5f55-44fd-8acf-92ee81ea6a39”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“trim”:false,“applicationSessionUuid”:“dd262401-421d-493b-9b2b-d693554455ea”,“flashingWorkflowUuid”:“c7eecd4a-0bac-494d-816b-dd7c68be220b”,“sample”:0.1})
image-writer.js:249 Terminating IPC server
C:\Users\Alpha\AppData\Local\Temp\1UvXH4mUtGaXW8AKaReztrB3uou\resources\app.asar\node_modules\resin-corvus\src\resin-corvus.js:39 Mon Feb 24 2020 16:36:50 GMT-0800 (Pacific Standard Time) Navigate ({“to”:“success”,“from”:“main”,“applicationSessionUuid”:“dd262401-421d-493b-9b2b-d693554455ea”,“sample”:0.1})
