Good morning, i have problems when installing Tails with Balema Etcher: when the installing phase is correctly complete i cannot find my usb where i have installed tails, so it is impossible to run. please help
if I understand correctly you reached the “Flash successful” screen in balenaEtcher.
Since the concents of your usb drive is equivalent to the Tails img you secelted, it has linux partitions, which are not necessarily visible in windows explorer.
You may continue and reboot your computer and select your USB as the boot device, you may need to press F10, Del, T, depending on your computer to do so.
