EtcherPro - Unable to write to location error
Getting the “Looks like etcher is not able to write to this location of the drive … usually caused by a faulty drive, SD-card reader, or USB-port.” I have 15 cards cloning in EtcherPro. How do I know which one is causing the error message?
Hello @GlenG , after you complete the cloning can you spot any red LED light on your ports? This should indicate which one is causing the error message, also you could try a power cycle (unplug your device from its power source and plug it back again) in case there’s an error with Etcher.
There were no red lights. I did not power cycle, but the second attempt completed successfully.
