Hi
I am trying to etch an zip file containing the iso for Raspbian Jessie using Etcher 1.4.4 on Win10 (64bit). I get a verification error as below. Any assistance would be greatly appreciated - thanks. I have tried this with older version of Jessie and after unzipping and formatting the SD card too - same outcome in all cases. Thanks.
Mon Sep 03 2018 17:10:47 GMT+1000 (AUS Eastern Standard Time) Verifying 1 devices, 99% at 15.4 MB/s (total 15.4 MB/s) eta in 0.29192154255319147s with 0 failed devices
gui.js:105081 Fail: Object {device: “\.\PhysicalDrive1”, error: Object}device: "\.\PhysicalDrive1"error: Objectcode: "EVALIDATION"message: "Verification failed: {“sha512”:“78113b08ecd25f0b3817e08f8b24fa30559236e40facbea60023122e952fdd84902702b265289297e7504cf445f5899a751b21194ed44f076d909fef11e22a06”} != {“sha512”:“9d4fa21615978e22da4f4cf2b17b95b702dd333c4423000b806b22f4ab7a8882eccb66ccfa959b17aadf1920a8faabf32aa10db85a9c2fdffde005c107c851b3”}"name: “Error"stack: “Error: Verification failed: {“sha512”:“78113b08ecd25f0b3817e08f8b24fa30559236e40facbea60023122e952fdd84902702b265289297e7504cf445f5899a751b21194ed44f076d909fef11e22a06”} != {“sha512”:“9d4fa21615978e22da4f4cf2b17b95b702dd333c4423000b806b22f4ab7a8882eccb66ccfa959b17aadf1920a8faabf32aa10db85a9c2fdffde005c107c851b3”}↵    at Pipeline.pipeline.on (C:\Users\z9600866\AppData\Local\Programs\etcher\resources\app.asar\lib\sdk\writer\index.js:525:25)↵    at emitOne (events.js:96:13)↵    at Pipeline.emit (events.js:191:7)↵    at ChecksumStream.stream.pipageListeners.(anonymous function) (C:\Users\z9600866\AppData\Local\Programs\etcher\resources\app.asar\node_modules\pipage\lib\pipeline.js:213:26)↵    at emitOne (events.js:96:13)↵    at ChecksumStream.emit (events.js:191:7)↵    at check (C:\Users\z9600866\AppData\Local\Programs\etcher\resources\app.asar\lib\sdk\writer\checksum-stream.js:84:14)↵    at Hash.hash.once (C:\Users\z9600866\AppData\Local\Programs\etcher\resources\app.asar\lib\sdk\writer\checksum-stream.js:94:7)↵    at Object.onceWrapper (events.js:293:19)↵    at emitNone (events.js:86:13)↵    at Hash.emit (events.js:188:7)↵    at emitReadable (_stream_readable.js:434:10)↵    at emitReadable (_stream_readable.js:428:7)↵    at readableAddChunk (_stream_readable.js:189:13)↵    at Hash.Readable.push (stream_readable.js:136:10)↵    at Hash.Transform.push (stream_transform.js:128:32)"proto: Object__proto: Object
gui.js:105081 Mon Sep 03 2018 17:10:47 GMT+1000 (AUS Eastern Standard Time) Flashing 0 devices, 100% at 0 MB/s (total 0 MB/s) eta in 0s with 1 failed devices
gui.js:105081 Finish: 4661484032
gui.js:105081 Flash results Object {results: Object, cancelled: false}
gui.js:105081 Terminating IPC server
gui.js:105081 Mon Sep 03 2018 17:10:51 GMT+1000 (AUS Eastern Standard Time) Done ({“image”:“C:\Users\z9600866\Downloads\2017-07-05-raspbian-jessie (1).zip”,“drives”:[”\\.\PhysicalDrive1”],“uuid”:“658e6728-3d48-4a45-aca5-ea26a4abe874”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true})
gui.js:105081 etcher:sdk:scanner start +11m true
gui.js:105081 Mon Sep 03 2018 17:10:51 GMT+1000 (AUS Eastern Standard Time) Navigate ({“to”:“success”,“from”:“main”})
