Etcher v1.1.2 release
The latest Etcher is out, get it from https://etcher.io/!
We’re moving towards more continuous releases, so we can get the fixes and features we build into Etcher to our users even faster! This release mostly contains bug fixes, to keep making Etcher even more stable!
Features
  • Add support for .rpi-sdcard images
Fixes
  • Avoid “broken” icon when selecting a zip image archive with invalid SVG
  • Fix UNABLE_TO_GET_ISSUER_CERT_LOCALLY error at startup when behind certain proxies
  • Fix EHOSTDOWN error at startup
  • Display a user-friendly error message if the user is not in the sudoers file
  • Make archive-embedded SVG icons work again
  • Fix “imageBasename is not defined” error on the CLI
  • Fix various drive scanning Windows errors
Misc
  • Improve Windows drive detection error codes.
When I try to use Etcher v1.1.2 I get an error saying; ERROR couldn’t scan the drives, permission error after start up. I am running Windows 10 on a Toshiba laptop and I can see the micro sd card is detected as drive E. How do I get Etcher to see the sd card as an available drive?
Big tank you for new Etcher version! (Sorry for bad English)
