Hello, I have been trying to use balenaEtcher to make a Pop!OS bootable USB. I let it do everything and it said it succeeded, but when I look in disk management, the flash drive is just all unformatted as if all Etcher did was unformat the drive
Hi
That’s quite strange. Can you
- share the version of Etcher you are using
- the OS on which you are using Etcher
- I am assuming this is the latest Pop OS! image - is that right?
Im using v1.5.121
Windows 11 Home
Yes, i am using the latest version of Pop OS!
However, as it showed unformatted and did not show up in windows (maybe because its windows 11), I was able to boot from it and install Pop OS!, so it may just be a bug with windows 11
