I tried re-installing the app and that did not fix it.
What is going on and how do I fix it?
Also the window with the error message has control of the app so to kill it have to go the process table and do a forced quit.
If you see that message and can dismiss it, you can just do so and continue using the app normally, although that’s the update notification (fixed in the next version to come) so you might want to update to the latest BalenaEtcher to make it go away
