Error when deploy balena-sound app to raspberry pi 3
Hello all,
i am brand new to balena and i am testing the balena sound. i deployed balena os and i am trying to deploy balena sound and i am ending with the below error
Error: Failed to fetch tarball from passed URL
Please assist to overcome this.
Thank you,
Hello @krisp.spotify first of all welcome to the balena community!
could you please share more details of the error? when is this happening? from balena CLI when you do balena push?
@mpous hi, thank you for your time taken to respond, I managed to push via CLI but now the challenge is, It keeps disconnecting and pausing the Spotify from the player. Tried web player, windows spotify app and mobile spotify app and all results in the same. Additionally, i dont see any logs in the Logs console
hey, I made a video of the error.
I also can’t deploy it. It happens when I click the deploy button in this repo. Error appears top right corner (end of the video)
Hello @amster thanks for sharing! as @krisp.spotify mentioned if you use balena push using the balena CLI it works successfully.
In the meantime, I shared the error to the balena team to see what can happen!
any response? i have also same issue
Hello @sadeedp as mentioned above you will need to use the balena CLI and type balena push.
Let us know if that works.
i tried, but no success,
@sadeedp did you clone the project repo in your local disk?
Then, go to the directory in your local disk and try balena push and the name of the fleet. You can copy from the slug in the balenaCloud’s fleet.
Let me know if that works!
please advise the step to clone the project repo, actually i want to clone balena-adsb.
i am stuck at this point:
finally i done it…
Thanks for confirming that it worked @sadeedp
