when I flash ubuntu in my usb pen it says: “The writer process ended unexpectedly.” why? what can I do??
thanks
Hello, please provide the operating system and the version, BalenaEtcher version and what image were you flashing onto your pendrive. Thanks!
the last balenaEtcher version and the last version of ubuntu desktop
My version is MacOS 10.15.5
Does Etcher work on any other drive?
No
Hi, just to be sure: you’re running balenaEtcher v1.5.101 on Ubuntu 20.10? You can check the version in the settings.
If not, I’d suggest trying with that and if the issue still rises, open the dev.tools console with cmd + opt + i and paste here the logs so we can take a look at them.
I’m use a Mac for install Ubuntu.
Thank you for the correction, I misread the previous message and then forgot to update that part.
Please paste here the logs from the console when the issue happens again so we can take a look at what’s happening.
THIS?
Etcher svg:not(:root).svg-inline--fa { overflow: visible; }.svg-inline–fa {
display: inline-block;
font-size: inherit;
height: 1em;
overflow: visible;
vertical-align: -0.125em;
.svg-inline–fa.fa-lg {
vertical-align: -0.225em;
.svg-inline–fa.fa-w-1 {
width: 0.0625em;
.svg-inline–fa.fa-w-2 {
width: 0.125em;
.svg-inline–fa.fa-w-3 {
width: 0.1875em;
.svg-inline–fa.fa-w-4 {
width: 0.25em;
.svg-inline–fa.fa-w-5 {
width: 0.3125em;
.svg-inline–fa.fa-w-6 {
width: 0.375em;
.svg-inline–fa.fa-w-7 {
width: 0.4375em;
.svg-inline–fa.fa-w-8 {
width: 0.5em;
.svg-inline–fa.fa-w-9 {
width: 0.5625em;
.svg-inline–fa.fa-w-10 {
width: 0.625em;
.svg-inline–fa.fa-w-11 {
width: 0.6875em;
.svg-inline–fa.fa-w-12 {
width: 0.75em;
.svg-inline–fa.fa-w-13 {
width: 0.8125em;
.svg-inline–fa.fa-w-14 {
width: 0.875em;
.svg-inline–fa.fa-w-15 {
width: 0.9375em;
.svg-inline–fa.fa-w-16 {
width: 1em;
.svg-inline–fa.fa-w-17 {
width: 1.0625em;
.svg-inline–fa.fa-w-18 {
width: 1.125em;
.svg-inline–fa.fa-w-19 {
width: 1.1875em;
.svg-inline–fa.fa-w-20 {
width: 1.25em;
.svg-inline–fa.fa-pull-left {
margin-right: 0.3em;
width: auto;
.svg-inline–fa.fa-pull-right {
margin-left: 0.3em;
width: auto;
.svg-inline–fa.fa-border {
height: 1.5em;
.svg-inline–fa.fa-li {
width: 2em;
.svg-inline–fa.fa-fw {
width: 1.25em;
.fa-layers svg.svg-inline–fa {
bottom: 0;
left: 0;
margin: auto;
position: absolute;
right: 0;
top: 0;
.fa-layers {
height: 1em;
position: relative;
text-align: center;
width: 1em;
-webkit-transform-origin: center center;
.fa-layers-counter, .fa-layers-text {
position: absolute;
text-align: center;
.fa-layers-text {
left: 50%;
top: 50%;
-webkit-transform: translate(-50%, -50%);
.fa-layers-counter {
background-color: #ff253a;
border-radius: 1em;
-webkit-box-sizing: border-box;
color: #fff;
height: 1.5em;
line-height: 1;
max-width: 5em;
min-width: 1.5em;
overflow: hidden;
padding: 0.25em;
right: 0;
text-overflow: ellipsis;
top: 0;
-webkit-transform: scale(0.25);
-webkit-transform-origin: top right;
.fa-layers-bottom-right {
bottom: 0;
right: 0;
top: auto;
-webkit-transform-origin: bottom right;
.fa-layers-bottom-left {
bottom: 0;
left: 0;
right: auto;
top: auto;
-webkit-transform-origin: bottom left;
.fa-layers-top-right {
right: 0;
top: 0;
.fa-layers-top-left {
left: 0;
right: auto;
top: 0;
-webkit-transform-origin: top left;
.fa-lg {
font-size: 1.3333333333em;
line-height: 0.75em;
vertical-align: -0.0667em;
.fa-xs {
font-size: 0.75em;
.fa-sm {
font-size: 0.875em;
.fa-1x {
font-size: 1em;
.fa-2x {
font-size: 2em;
.fa-3x {
font-size: 3em;
.fa-4x {
font-size: 4em;
.fa-5x {
font-size: 5em;
.fa-6x {
font-size: 6em;
.fa-7x {
font-size: 7em;
.fa-8x {
font-size: 8em;
.fa-9x {
font-size: 9em;
.fa-10x {
font-size: 10em;
.fa-fw {
text-align: center;
width: 1.25em;
.fa-ul {
list-style-type: none;
margin-left: 2.5em;
padding-left: 0;
.fa-ul > li {
position: relative;
.fa-li {
left: -2em;
position: absolute;
text-align: center;
width: 2em;
line-height: inherit;
.fa-border {
border: solid 0.08em #eee;
border-radius: 0.1em;
padding: 0.2em 0.25em 0.15em;
.fa-pull-left {
float: left;
.fa-pull-right {
float: right;
.fa.fa-pull-left,
.fas.fa-pull-left,
.far.fa-pull-left,
.fal.fa-pull-left,
.fab.fa-pull-left {
.fa.fa-pull-right,
.fas.fa-pull-right,
.far.fa-pull-right,
.fal.fa-pull-right,
.fab.fa-pull-right {
margin-left: 0.3em;
.fa-spin {
-webkit-animation: fa-spin 2s infinite linear;
.fa-pulse {
-webkit-animation: fa-spin 1s infinite steps(8);
@-webkit-keyframes fa-spin {
0% {
-webkit-transform: rotate(0deg);
100% {
-webkit-transform: rotate(360deg);
@keyframes fa-spin {
0% {
100% {
.fa-rotate-90 {
-ms-filter: “progid:DXImageTransform.Microsoft.BasicImage(rotation=1)”;
-webkit-transform: rotate(90deg);
.fa-rotate-180 {
-ms-filter: “progid:DXImageTransform.Microsoft.BasicImage(rotation=2)”;
-webkit-transform: rotate(180deg);
.fa-rotate-270 {
-ms-filter: “progid:DXImageTransform.Microsoft.BasicImage(rotation=3)”;
-webkit-transform: rotate(270deg);
.fa-flip-horizontal {
-ms-filter: “progid:DXImageTransform.Microsoft.BasicImage(rotation=0, mirror=1)”;
-webkit-transform: scale(-1, 1);
.fa-flip-vertical {
-ms-filter: “progid:DXImageTransform.Microsoft.BasicImage(rotation=2, mirror=1)”;
-webkit-transform: scale(1, -1);
.fa-flip-both, .fa-flip-horizontal.fa-flip-vertical {
-webkit-transform: scale(-1, -1);
:root .fa-rotate-90,
:root .fa-rotate-180,
:root .fa-rotate-270,
:root .fa-flip-horizontal,
:root .fa-flip-vertical,
:root .fa-flip-both {
-webkit-filter: none;
filter: none;
.fa-stack {
height: 2em;
position: relative;
width: 2.5em;
.fa-stack-1x,
.fa-stack-2x {
bottom: 0;
left: 0;
margin: auto;
position: absolute;
right: 0;
top: 0;
.svg-inline–fa.fa-stack-1x {
height: 1em;
width: 1.25em;
.svg-inline–fa.fa-stack-2x {
height: 2em;
width: 2.5em;
.fa-inverse {
color: #fff;
.sr-only {
border: 0;
clip: rect(0, 0, 0, 0);
height: 1px;
margin: -1px;
overflow: hidden;
padding: 0;
position: absolute;
width: 1px;
.sr-only-focusable:active, .sr-only-focusable:focus {
clip: auto;
height: auto;
margin: 0;
overflow: visible;
position: static;
width: auto;
.svg-inline–fa .fa-primary {
fill: var(–fa-primary-color, currentColor);
opacity: 1;
opacity: var(–fa-primary-opacity, 1);
.svg-inline–fa .fa-secondary {
fill: var(–fa-secondary-color, currentColor);
opacity: 0.4;
opacity: var(–fa-secondary-opacity, 0.4);
.svg-inline–fa.fa-swap-opacity .fa-primary {
opacity: 0.4;
.svg-inline–fa.fa-swap-opacity .fa-secondary {
opacity: 1;
.svg-inline–fa mask .fa-primary,
.svg-inline–fa mask .fa-secondary {
fill: black;
.fad.fa-inverse {
color: #fff;
THIS?
font-size: inherit;
height: 1em;
overflow: visible;
width: 0.0625em;
width: 0.125em;
width: 0.1875em;
width: 0.25em;
width: 0.3125em;
width: 0.375em;
width: 0.4375em;
width: 0.5em;
width: 0.5625em;
width: 0.625em;
width: 0.6875em;
width: 0.75em;
width: 0.8125em;
width: 0.875em;
width: 0.9375em;
width: 1em;
width: 1.0625em;
width: 1.125em;
width: 1.1875em;
width: 1.25em;
width: auto;
margin-left: 0.3em;
width: auto;
height: 1.5em;
width: 2em;
width: 1.25em;
bottom: 0;
left: 0;
margin: auto;
position: absolute;
right: 0;
top: 0;
.fa-layers {
height: 1em;
position: relative;
text-align: center;
width: 1em;
position: absolute;
text-align: center;
.fa-layers-text {
left: 50%;
top: 50%;
border-radius: 1em;
color: #fff;
height: 1.5em;
line-height: 1;
max-width: 5em;
min-width: 1.5em;
overflow: hidden;
padding: 0.25em;
right: 0;
top: 0;
bottom: 0;
right: 0;
top: auto;
bottom: 0;
left: 0;
right: auto;
top: auto;
right: 0;
top: 0;
left: 0;
right: auto;
top: 0;
.fa-lg {
.fa-xs {
font-size: 0.75em;
.fa-sm {
font-size: 0.875em;
.fa-1x {
font-size: 1em;
.fa-2x {
font-size: 2em;
.fa-3x {
font-size: 3em;
.fa-4x {
font-size: 4em;
.fa-5x {
font-size: 5em;
.fa-6x {
font-size: 6em;
.fa-7x {
font-size: 7em;
.fa-8x {
font-size: 8em;
.fa-9x {
font-size: 9em;
.fa-10x {
font-size: 10em;
.fa-fw {
text-align: center;
width: 1.25em;
.fa-ul {
margin-left: 2.5em;
padding-left: 0;
.fa-ul > li {
position: relative;
.fa-li {
left: -2em;
position: absolute;
text-align: center;
width: 2em;
.fa-border {
.fa-pull-left {
float: left;
.fa-pull-right {
float: right;
.fa.fa-pull-left,
.fas.fa-pull-left,
.far.fa-pull-left,
.fal.fa-pull-left,
.fab.fa-pull-left {
.fa.fa-pull-right,
.fas.fa-pull-right,
.far.fa-pull-right,
.fal.fa-pull-right,
margin-left: 0.3em;
.fa-spin {
.fa-pulse {
0% {
100% {
0% {
100% {
.fa-rotate-90 {
.fa-rotate-180 {
.fa-rotate-270 {
.fa-flip-vertical {
filter: none;
.fa-stack {
height: 2em;
position: relative;
width: 2.5em;
.fa-stack-1x,
.fa-stack-2x {
bottom: 0;
left: 0;
margin: auto;
position: absolute;
right: 0;
top: 0;
height: 1em;
width: 1.25em;
height: 2em;
width: 2.5em;
.fa-inverse {
color: #fff;
.sr-only {
border: 0;
height: 1px;
margin: -1px;
overflow: hidden;
padding: 0;
position: absolute;
width: 1px;
clip: auto;
height: auto;
margin: 0;
overflow: visible;
position: static;
width: auto;
opacity: 1;
opacity: 0.4;
opacity: 0.4;
opacity: 1;
fill: black;
.fad.fa-inverse {
color: #fff;
Hi, can you click on the console tab and send us the output from there, your screenshot is on the Elements tab, also it would be great to paste here the output of the console, screenshots can show a limited amount of information. Thanks!
this?
| | | | | | ___ _ __
| || / | ’ \ / _ \ '|
_/ ____|| ||___||
Interested in joining the Etcher team?
Drop us a line at join+etcher@balena.io
Version = 1.5.101, Type = dmg
gui.js:132986 Tue Jul 14 2020 23:04:55 GMT+0200 (Ora legale dell’Europa centrale) Application start ({“packageType”:“dmg”,“version”:“1.5.101”,“sample”:0.1,“applicationSessionUuid”:“224c53a6-62a3-4248-94a9-903231635e0a”,“flashingWorkflowUuid”:“7d12c883-ec74-49f7-94d8-5072bc7af229”})
gui.js:125688 Tue Jul 14 2020 23:04:58 GMT+0200 (Ora legale dell’Europa centrale) Open image selector ({“sample”:0.1,“applicationSessionUuid”:“224c53a6-62a3-4248-94a9-903231635e0a”,“flashingWorkflowUuid”:“7d12c883-ec74-49f7-94d8-5072bc7af229”})
gui.js:125688 Tue Jul 14 2020 23:05:22 GMT+0200 (Ora legale dell’Europa centrale) Select image ({“image”:{“size”:2715254784,“name”:“ubuntu-20.04-desktop-amd64.iso”,“hasMBR”:true,“partitions”:[{“offset”:2161991680,“size”:4063232,“type”:239,“index”:1}],“path”:"/Users/dada07tv/Desktop/ubuntu-20.04-desktop-amd64.iso",“extension”:“iso”,“logo”:false,“blockMap”:false},“sample”:0.1,“applicationSessionUuid”:“224c53a6-62a3-4248-94a9-903231635e0a”,“flashingWorkflowUuid”:“7d12c883-ec74-49f7-94d8-5072bc7af229”})
gui.js:125688 Tue Jul 14 2020 23:05:25 GMT+0200 (Ora legale dell’Europa centrale) Toggle drive ({“drive”:{“size”:15676211200,“isVirtual”:false,“enumerator”:“DiskArbitration”,“logicalBlockSize”:512,“raw”:"/dev/rdisk3",“error”:null,“isReadOnly”:false,“displayName”:"/dev/disk3",“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"/dev/disk3",“busVersion”:null,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:“IODeviceTree:/PCI0@0/XHC1@14”,“mountpoints”:[{“path”:"/Volumes/Transcend",“label”:“Transcend”}],“description”:“JetFlash Transcend 16GB Media”,“isUAS”:null},“previouslySelected”:false,“sample”:0.1,“applicationSessionUuid”:“224c53a6-62a3-4248-94a9-903231635e0a”,“flashingWorkflowUuid”:“7d12c883-ec74-49f7-94d8-5072bc7af229”})
gui.js:125688 Tue Jul 14 2020 23:06:27 GMT+0200 (Ora legale dell’Europa centrale) Toggle drive ({“drive”:{“size”:15676211200,“isVirtual”:false,“enumerator”:“DiskArbitration”,“logicalBlockSize”:512,“raw”:"/dev/rdisk3",“error”:null,“isReadOnly”:false,“displayName”:"/dev/disk3",“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"/dev/disk3",“busVersion”:null,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:“IODeviceTree:/PCI0@0/XHC1@14”,“mountpoints”:,“description”:“JetFlash Transcend 16GB Media”,“isUAS”:null},“previouslySelected”:false,“sample”:0.1,“applicationSessionUuid”:“224c53a6-62a3-4248-94a9-903231635e0a”,“flashingWorkflowUuid”:“7d12c883-ec74-49f7-94d8-5072bc7af229”})
gui.js:125688 Tue Jul 14 2020 23:06:30 GMT+0200 (Ora legale dell’Europa centrale) Toggle drive ({“drive”:{“size”:15676211200,“isVirtual”:false,“enumerator”:“DiskArbitration”,“logicalBlockSize”:512,“raw”:"/dev/rdisk3",“error”:null,“isReadOnly”:false,“displayName”:"/dev/disk3",“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"/dev/disk3",“busVersion”:null,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:“IODeviceTree:/PCI0@0/XHC1@14”,“mountpoints”:[{“path”:"/Volumes/Transcend",“label”:“Transcend”}],“description”:“JetFlash Transcend 16GB Media”,“isUAS”:null},“previouslySelected”:false,“sample”:0.1,“applicationSessionUuid”:“224c53a6-62a3-4248-94a9-903231635e0a”,“flashingWorkflowUuid”:“7d12c883-ec74-49f7-94d8-5072bc7af229”})
gui.js:125688 Tue Jul 14 2020 23:06:33 GMT+0200 (Ora legale dell’Europa centrale) Flash ({“image”:"/Users/dada07tv/Desktop/ubuntu-20.04-desktop-amd64.iso",“drives”:[{“size”:15676211200,“isVirtual”:false,“enumerator”:“DiskArbitration”,“logicalBlockSize”:512,“raw”:"/dev/rdisk3",“error”:null,“isReadOnly”:false,“displayName”:"/dev/disk3",“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"/dev/disk3",“busVersion”:null,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:“IODeviceTree:/PCI0@0/XHC1@14”,“mountpoints”:[{“path”:"/Volumes/Transcend",“label”:“Transcend”}],“description”:“JetFlash Transcend 16GB Media”,“isUAS”:null}],“driveCount”:1,“uuid”:“88cdfb93-9ad6-49db-95c5-ac4566e24967”,“status”:“started”,“flashInstanceUuid”:“88cdfb93-9ad6-49db-95c5-ac4566e24967”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“sample”:0.1,“applicationSessionUuid”:“224c53a6-62a3-4248-94a9-903231635e0a”,“flashingWorkflowUuid”:“7d12c883-ec74-49f7-94d8-5072bc7af229”})
gui.js:125688 Elevating command: /Applications/balenaEtcher.app/Contents/Frameworks/balenaEtcher Helper (Renderer).app/Contents/MacOS/balenaEtcher Helper (Renderer) /Applications/balenaEtcher.app/Contents/Resources/app
gui.js:125688 Tue Jul 14 2020 23:06:34 GMT+0200 (Ora legale dell’Europa centrale) SafeWebview loaded ({“event”:{“id”:1,“url”:“https://assets.balena.io/etcher-featured/index.html?borderRight=false&darkBackground=true&etcher-version=1.5.101&api-version=2&optOutAnalytics=false",“method”:“GET”,“timestamp”:1594760794489.939,“resourceType”:“mainFrame”,“ip”:“104.31.83.157”,“fromCache”:false,“statusLine”:"HTTP/1.1 200”,“statusCode”:200,“responseHeaders”:{“access-control-allow-origin”:["*"],“age”:[“0”],“cache-control”:[“max-age=600”],“cf-cache-status”:[“DYNAMIC”],“cf-ray”:[“5b2e35550843cd2a-FCO”],“cf-request-id”:[“03f0bfa9260000cd2a57059200000001”],“content-encoding”:[“br”],“content-type”:[“text/html; charset=utf-8”],“date”:[“Tue, 14 Jul 2020 21:06:34 GMT”],“expect-ct”:[“max-age=604800, report-uri=“https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct””],“expires”:[“Mon, 13 Jul 2020 11:03:22 GMT”],“last-modified”:[“Wed, 17 Jun 2020 21:19:41 GMT”],“server”:[“cloudflare”],“status”:[“200”],“vary”:[“Accept-Encoding”],“via”:[“1.1 varnish”],“x-cache”:[“HIT”],“x-cache-hits”:[“1”],“x-fastly-request-id”:[“eee4e114d25a28725b9dbf0aaaa13f63e7e91653”],“x-github-request-id”:[“CD2E:515C:789685:9460A8:5F0C3D95”],“x-proxy-cache”:[“HIT”],“x-served-by”:[“cache-mxp19833-MXP”],“x-timer”:[“S1594760794.443433,VS0,VE103”]},“referrer”:"",“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“224c53a6-62a3-4248-94a9-903231635e0a”,“flashingWorkflowUuid”:“7d12c883-ec74-49f7-94d8-5072bc7af229”})
gui.js:7847 0 devices, 0% at 0.00 MB/s (total 0.00 MB/s) with 0 failed devices
gui.js:125688 Successfully connected to IPC server: etcher-server-38267, socket root /var/folders/mt/93_mb8js4hxc95mv009msgfh0000gs/T/
gui.js:125688 Image: /Users/dada07tv/Desktop/ubuntu-20.04-desktop-amd64.iso
gui.js:125688 Devices: /dev/disk3
gui.js:125688 Umount on success: true
gui.js:125688 Validate on success: true
gui.js:125688 Auto blockmapping: true
gui.js:125688 Decompress first: true
gui.js:125688 Tue Jul 14 2020 23:06:51 GMT+0200 (Ora legale dell’Europa centrale) Flash error ({“image”:"/Users/dada07tv/Desktop/ubuntu-20.04-desktop-amd64.iso",“drives”:[{“size”:15676211200,“isVirtual”:false,“enumerator”:“DiskArbitration”,“logicalBlockSize”:512,“raw”:"/dev/rdisk3",“error”:null,“isReadOnly”:false,“displayName”:"/dev/disk3",“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"/dev/disk3",“busVersion”:null,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:“IODeviceTree:/PCI0@0/XHC1@14”,“mountpoints”:[{“path”:"/Volumes/Transcend",“label”:“Transcend”}],“description”:“JetFlash Transcend 16GB Media”,“isUAS”:null}],“driveCount”:1,“uuid”:“88cdfb93-9ad6-49db-95c5-ac4566e24967”,“flashInstanceUuid”:“88cdfb93-9ad6-49db-95c5-ac4566e24967”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“error”:{“name”:“Error”,“message”:“EPERM: operation not permitted, open ‘/dev/rdisk3’”,“stack”:“Error: EPERM: operation not permitted, open ‘/dev/rdisk3’”,“code”:“EPERM”,“syscall”:“open”,“errno”:-1},“sample”:0.1,“applicationSessionUuid”:“224c53a6-62a3-4248-94a9-903231635e0a”,“flashingWorkflowUuid”:“7d12c883-ec74-49f7-94d8-5072bc7af229”})
gui.js:125688 Finish: 0
gui.js:125688 Terminating IPC server
gui.js:125688 Flash results {results: {…}, cancelled: false}
gui.js:125688 Tue Jul 14 2020 23:06:51 GMT+0200 (Ora legale dell’Europa centrale) Write failed ({“image”:"/Users/dada07tv/Desktop/ubuntu-20.04-desktop-amd64.iso",“drives”:[{“size”:15676211200,“isVirtual”:false,“enumerator”:“DiskArbitration”,“logicalBlockSize”:512,“raw”:"/dev/rdisk3",“error”:null,“isReadOnly”:false,“displayName”:"/dev/disk3",“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"/dev/disk3",“busVersion”:null,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:“IODeviceTree:/PCI0@0/XHC1@14”,“mountpoints”:[{“path”:"/Volumes/Transcend",“label”:“Transcend”}],“description”:“JetFlash Transcend 16GB Media”,“isUAS”:null}],“driveCount”:1,“uuid”:“88cdfb93-9ad6-49db-95c5-ac4566e24967”,“status”:“failed”,“flashInstanceUuid”:“88cdfb93-9ad6-49db-95c5-ac4566e24967”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“error”:{“description”:“Please try again, and contact the Etcher team if the problem persists”,“report”:false,“code”:“ECHILDDIED”},“sample”:0.1,“applicationSessionUuid”:“224c53a6-62a3-4248-94a9-903231635e0a”,“flashingWorkflowUuid”:“7d12c883-ec74-49f7-94d8-5072bc7af229”})
Hi. Can you try sudo /Applications/balenaEtcher.app/Contents/MacOS/balenaEtcherto see if it works with elevated permissions?
no it doesn’t go
Could you share the output of trying to run the command with sudo please? It’s unclear whether the issue is the admin access or not.
ok: (node:77405) Electron: Loading non-context-aware native module in renderer: ‘/Applications/balenaEtcher.app/Contents/Resources/app/generated/modules/xxhash/build/Release/hash.node’. This is deprecated, see https://github.com/electron/electron/issues/18397.
(node:77405) Electron: Loading non-context-aware native module in renderer: ‘/Applications/balenaEtcher.app/Contents/Resources/app/generated/modules/ext2fs/build/Release/bindings.node’. This is deprecated, see https://github.com/electron/electron/issues/18397.
(node:77405) Electron: Loading non-context-aware native module in renderer: ‘/Applications/balenaEtcher.app/Contents/Resources/app/generated/modules/drivelist/build/Release/drivelist.node’. This is deprecated, see https://github.com/electron/electron/issues/18397.
(node:77405) Electron: Loading non-context-aware native module in renderer: ‘/Applications/balenaEtcher.app/Contents/Resources/app/generated/modules/@balena.io/usb/build/Release/usb_bindings.node’. This is deprecated, see https://github.com/electron/electron/issues/18397.
ready-to-show: 1251.007ms
Checking for update
Error: Error: net::ERR_CERT_INVALID
at SimpleURLLoaderWrapper. (electron/js2c/browser_init.js:2575:21)
at SimpleURLLoaderWrapper.emit (events.js:223:5)
{“stack”:“Error: net::ERR_CERT_INVALID\n at SimpleURLLoaderWrapper. (electron/js2c/browser_init.js:2575:21)\n at SimpleURLLoaderWrapper.emit (events.js:223:5)”,“message”:“net::ERR_CERT_INVALID”}
Hi, can you explain what happens, when you start etcher as sudo ? You posted the command console output. Can you please post the output of the browser console as before ?
Fri Jul 31 2020 23:57:34 GMT+0200 (Central European Summer Time) Application start ({“packageType”:“dmg”,“version”:“1.5.101”,“sample”:0.1,“applicationSessionUuid”:“d9aa15fd-9f9d-4726-88e5-3efe194210d1”,“flashingWorkflowUuid”:“de4c5496-0907-46c6-b283-2971c26e0b6d”})
