rj17
January 17, 2020, 10:16pm
1
I’m on MacOsX Catalina 10.15.2 and Etcher 1.5.71. When I try to flash my USB to install Ubuntu, there is this message :
the writer process ended unexpectedly. Please try again, …
I try this Terminal command but it doesn’t work :
sudo /Applications/balenaEtcher.app/Contents/MacOS/balenaEtcher
Thank you for your help
RJ17
Hi rj17, and welcome to the forums.
To give us more information, can you paste the logs from the application? You can see them by opening the DevTools Console with cmd + opt + i.
Additionally, you could also try with another image to rule out an issue with the image itself.
Thanks for that. This looks similar to this issue https://github.com/balena-io/etcher/issues/2833 - could you try that workaround and see if that resolves your issue?
rj17
January 18, 2020, 6:21am
6
It works !
Under Catalina one must add the application to the security exceptions:
Go to “ System Preferences ” -> “ Security & Privacy ” -> “ Privacy “.
Add the application to the list of “ Full Disk Access “ items, and you should be good to go.
No need to run as sudo.
Thank you so much !
