I’ve tried many workarounds such as Running as admin, partitioning of the sd card using different types, redownloading the windows file and I still get the same error everytime. Any insights with this?
What is the file you are trying to flash? If it is a Windows image note that they will not work without further adjustments. See etcher/docs/USER-DOCUMENTATION.md at master · balena-io/etcher · GitHub
