OK, so version 2.1.0 on an Intel Mac. Had this problem on and off. Suggested solution is to run as admin which is a pain at best on a Mac. Don’t know if these forums are read by the devs but this is my commandline log from starting as admin. Result is the same on selecting file - Error: (0 , h.requestMetadata) is not a function.
sudo /Applications/balenaEtcher.app/Contents/MacOS/balenaEtcher
Password:
d {
_notifyingListeners: false,
_scopeListeners: [ [Function: o] ],
_eventProcessors: ,
_breadcrumbs: [
timestamp: 1746613029.394,
category: ‘console’,
level: ‘log’,
message: ‘d {\n’ +
’ _notifyingListeners: false,\n’ +
’ _scopeListeners: [ [Function: o] ],\n’ +
’ _eventProcessors: ,\n’ +
’ _breadcrumbs: ,\n’ +
’ _attachments: ,\n’ +
’ _user: {},\n’ +
’ _tags: {},\n’ +
’ _extra: {},\n’ +
’ _contexts: {},\n’ +
’ _sdkProcessingMetadata: {},\n’ +
’ _propagationContext: {\n’ +
" traceId: ‘39a052c672f3454aae764960b13c9931’,\n" +
" spanId: ‘abd95fd1cc98de95’\n" +
’ },\n’ +
’ _client: k {\n’ +
’ _options: {\n’ +
’ _metadata: [Object],\n’ +
’ ipcMode: 3,\n’ +
’ getSessions: [Function: getSessions],\n’ +
" dsn: ‘https://739bbcfc0ba4481481138d3fc831136d@o95242.ingest.sentry.io/4504451487301632’,\n" +
’ beforeSend: [Function (anonymous)],\n’ +
’ debug: false,\n’ +
" release: ‘balenaEtcher@2.1.0’,\n" +
" environment: ‘production’,\n" +
’ autoSessionTracking: false,\n’ +
’ stackParser: [Function (anonymous)],\n’ +
’ defaultIntegrations: [Array],\n’ +
’ transport: [Function (anonymous)],\n’ +
" instrumenter: ‘sentry’,\n" +
’ integrations: [Array],\n’ +
’ transportOptions: [Object],\n’ +
" platform: ‘node’,\n" +
’ runtime: [Object],\n’ +
" serverName: ‘MyMac’\n" +
’ },\n’ +
’ _integrations: {\n’ +
’ SentryMinidump: [Object],\n’ +
’ ElectronBreadcrumbs: [Object],\n’ +
’ Net: [Object],\n’ +
’ MainContext: [Object],\n’ +
’ ChildProcess: [Object],\n’ +
’ OnUncaughtException: [Object],\n’ +
’ PreloadInjection: [Object],\n’ +
’ AdditionalContext: [Object],\n’ +
’ Screenshots: [Object],\n’ +
’ RendererProfiling: [Object],\n’ +
’ InboundFilters: [Object],\n’ +
’ FunctionToString: [Object],\n’ +
’ LinkedErrors: [Object],\n’ +
’ RequestData: [Object],\n’ +
’ Console: [Object],\n’ +
’ Http: [Me],\n’ +
’ Undici: [_t],\n’ +
’ OnUnhandledRejection: [Object],\n’ +
’ ContextLines: [Object],\n’ +
’ LocalVariables: [Object],\n’ +
’ Modules: [Object],\n’ +
’ MainProcessSession: [Object]\n’ +
’ },\n’ +
’ _integrationsInitialized: true,\n’ +
’ _numProcessing: 0,\n’ +
’ _outcomes: {},\n’ +
’ _hooks: { preprocessEvent: [Array] },\n’ +
’ _eventProcessors: [\n’ +
’ [Function],\n’ +
’ [Function],\n’ +
’ [Function],\n’ +
’ [Function],\n’ +
’ [Function],\n’ +
’ [Function],\n’ +
’ [Function],\n’ +
’ [Function]\n’ +
’ ],\n’ +
’ _dsn: {\n’ +
" protocol: ‘https’,\n" +
" publicKey: ‘739bbcfc0ba4481481138d3fc831136d’,\n" +
" pass: ‘’,\n" +
" host: ‘o95242.ingest.sentry.io’,\n" +
" port: ‘’,\n" +
" path: ‘’,\n" +
" projectId: ‘4504451487301632’\n" +
’ },\n’ +
’ _transport: { send: [Function], flush: [Function: flush] }\n’ +
’ },\n’ +
’ _session: {\n’ +
" sid: ‘3ab046293f7746acb99b14b96669d222’,\n" +
’ init: true,\n’ +
’ timestamp: 1746613029.391192,\n’ +
’ started: 1746613029.3911002,\n’ +
’ duration: 0.00009179115295410156,\n’ +
" status: ‘ok’,\n" +
’ errors: 0,\n’ +
’ ignoreDuration: false,\n’ +
’ toJSON: [Function: toJSON],\n’ +
’ did: undefined,\n’ +
" environment: ‘production’\n" +
’ }\n’ +
_attachments: ,
_user: {},
_tags: {},
_extra: {},
_contexts: {},
_client: k {
_options: {
ipcMode: 3,
debug: false,
platform: ‘node’,
runtime: [Object],
serverName: ‘MyMac’
_integrations: {
Net: [Object],
Console: [Object],
Http: [Me],
Undici: [_t],
Modules: [Object],
_numProcessing: 0,
_outcomes: {},
_eventProcessors: [
[Function],
[Function],
[Function],
[Function],
[Function],
[Function],
[Function],
[Function]
_dsn: {
protocol: ‘https’,
pass: ‘’,
port: ‘’,
path: ‘’,
_session: {
init: true,
status: ‘ok’,
errors: 0,
did: undefined,
Language changed to: en
ready-to-show: 32.834s
packageUpdatable false
[29628:0507/121820.440373:ERROR:ssl_client_socket_impl.cc(879)] handshake failed; returned -1, SSL error code 1, net_error -100
[29628:0507/121820.441437:ERROR:ssl_client_socket_impl.cc(879)] handshake failed; returned -1, SSL error code 1, net_error -100
[29618:0507/121820.646602:ERROR:trust_store_mac.cc(750)] Error parsing certificate:
ERROR: Failed parsing extensions
[29628:0507/121822.080447:ERROR:ssl_client_socket_impl.cc(879)] handshake failed; returned -1, SSL error code 1, net_error -100
[29628:0507/121822.081102:ERROR:ssl_client_socket_impl.cc(879)] handshake failed; returned -1, SSL error code 1, net_error -100
[29628:0507/121822.081559:ERROR:ssl_client_socket_impl.cc(879)] handshake failed; returned -1, SSL error code 1, net_error -100
2025-05-07 12:18:40.434 balenaEtcher[29618:1365937] +[CATransaction synchronize] called within transaction
2025-05-07 12:19:05.248 balenaEtcher[29618:1365937] +[CATransaction synchronize] called within transaction
2025-05-07 12:19:14.834 balenaEtcher[29618:1365937] +[CATransaction synchronize] called within transaction
2025-05-07 12:19:28.963 balenaEtcher[29618:1365937] +[CATransaction synchronize] called within transaction
2025-05-07 12:19:31.664 balenaEtcher[29618:1365937] +[CATransaction synchronize] called within transaction
2025-05-07 12:39:30.913 balenaEtcher[29618:1365937] +[CATransaction synchronize] called within transaction
