Okay, so I used this a couple weeks ago to make a Linux Mint Live Stick. Worked fine and I thought I was done with it, so I deleted the Linux and was going to use it as a plain Flash stick after that.
This has led to two problems
Turns out I need to reinstall Mint and now I need to remake the Live Stick.
I would just do this, but the stick now shows two drives. One near full sized, and a tiny one labeled efi.
I’ve tried formatting the drive to integrate the two partitions, but that has done squat. I don’t want to re-etch another Mint drive and end up with a second efi thing on it.
Is there a way thought Etcher, (or some other program?) to fix this? Or is there a better path to take?
I’m running Windows 10 and installing Mint into VMware Workstation if that helps.
Tourma
