resinOS is an open source project, so you can re-build it for a particular board to add any customization you might need. Check https://github.com/resin-os/resin-raspberrypi for the Raspberry Pi resinOS flavor, and don’t hesitate to get in touch if need help along the way.
Hi, looking at the current kernel (4.4.8) in the 2.0.0+rev3 release of resinOS, it comes with the rtl8192cu driver enabled - that’s the part that you wanted to add? Or is there any other thing that you needed to change? Have you gave that version of resinOS a try?
What exact changes / steps would you need monitoring to be enabled? The StackOverflow question is quite old, and would be good to have a specific list to see how to facilitate that for you.
If you still need to modify the image, the repository above have the information how to build it in the README. The kernel info you would need to change in the meta-raspberrypi layer. In meta-raspberrypi you’d need to change the settings within relevant files in the recipes-kernel/linux/ directory. That’s some work with Yocto, the build system we use, but should be able to find many resources online on how to work with that.
I actually need the rtlwifi modules enabled and the rtl8192cu drivers disabled. The rtlwifi drivers include monitoring capabilities, the other drivers do not.
We have some development planned that would help with this quite abut, but it’s not yet ready, unfortunately (will keep you posted for sure)
In the meantime probably you would need to dig into resin-raspberrypi and check the readme there how to compile things. The configurations are usually in recipes, so would think you would need to change the kernel configuration in the relevant layers/recipes, e.g in (I think) /layers/meta-resin-raspberrypi/recipes-kernel/linux/linux-raspberrypi_%.bbappend (this), where you would add your own configuration group and enable that. This whole setup is using Yocto, in case you need some more info for how to modify these layers, etc. (is that right, @andrei?)
