i’ve configured The Thing Stack v3 on my network (with IP static 192.168.43.199).
I’ve created a Gateway on my TTS console but the balenafin does not connect to the locally installed TTSv3.
In the dashboard of the balenafin i have entered the variable
TC_KEY: NNSXS.ZD3UBTMSXAEGUK3UVXZODT…
TC_URI: wss://192.168.43.199:8887
TC_TRUST: -----BEGIN CERTIFICATE----- MIIDtTCCAp2gAwI … Y4fXtHE= -----END CERTIFICATE-----
but I get this error:
23.11.21 09:13:32 (+0100) main Gateway EUI: b827ebfffe09fa6e
23.11.21 09:13:33 (+0100) main Using MODEL: SX1302
23.11.21 09:13:33 (+0100) main Server: wss://192.168.43.199:8887
23.11.21 09:13:33 (+0100) main Using variant=std, lns_config=’./lns-ttn’
23.11.21 09:13:33 (+0100) main Starting Station …
23.11.21 09:13:33 (+0100) main Killing process 37
23.11.21 09:13:33 (+0100) main 2021-11-23 08:13:33.659 [SYS:INFO] Logging : stderr (maxsize=10000000, rotate=3)
23.11.21 09:13:33 (+0100) main 2021-11-23 08:13:33.659 [SYS:INFO] Station Ver : 2.0.5(corecell/std) 2021-10-21 09:39:15
23.11.21 09:13:33 (+0100) main 2021-11-23 08:13:33.660 [SYS:INFO] Package Ver : 2.0.4
23.11.21 09:13:33 (+0100) main 2021-11-23 08:13:33.660 [SYS:INFO] proto EUI : 0:b827:eb09:fa6e (/sys/class/net/eth0/address)
23.11.21 09:13:33 (+0100) main 2021-11-23 08:13:33.660 [SYS:INFO] prefix EUI : ::1 (builtin)
23.11.21 09:13:33 (+0100) main 2021-11-23 08:13:33.660 [SYS:INFO] Station EUI : b827:ebff:fe09:fa6e
23.11.21 09:13:33 (+0100) main 2021-11-23 08:13:33.660 [SYS:INFO] Station home: ./lns-ttn/ (–home)
23.11.21 09:13:33 (+0100) main 2021-11-23 08:13:33.660 [SYS:INFO] Station temp: /var/tmp/ (builtin)
23.11.21 09:13:33 (+0100) main 2021-11-23 08:13:33.660 [SYS:WARN] Station in NO-CUPS mode
23.11.21 09:13:34 (+0100) main 2021-11-23 08:13:33.862 [TCE:INFO] Starting TC engine
23.11.21 09:13:34 (+0100) main 2021-11-23 08:13:33.872 [any:INFO] ./lns-ttn/tc.trust:
23.11.21 09:13:34 (+0100) main cert. version : 3
23.11.21 09:13:34 (+0100) main serial number : 1D:C4:B0:25:FB:D5:82:2B:93:65:EA:D1:84:05:20:C2:AB:21:55:5F
23.11.21 09:13:34 (+0100) main issuer name : C=IT, ST=Some-State, L=Bologna, O=CAi4s.example.com, CN=192.168.43.199
23.11.21 09:13:34 (+0100) main subject name : C=IT, ST=Some-State, L=Bologna, O=CAi4s.example.com, CN=192.168.43.199
23.11.21 09:13:34 (+0100) main issued on : 2021-11-16 15:03:06
23.11.21 09:13:34 (+0100) main expires on : 3021-03-19 15:03:06
23.11.21 09:13:34 (+0100) main signed using : RSA with SHA-256
23.11.21 09:13:34 (+0100) main RSA key size : 2048 bits
23.11.21 09:13:34 (+0100) main basic constraints : CA=t2021-11-23 08:13:33.873 [AIO:INFO] tc has no cert configured - running server auth and client auth with token
23.11.21 09:13:34 (+0100) main 2021-11-23 08:13:33.893 [TCE:INFO] Connecting to INFOS: wss://192.168.43.199:8887
23.11.21 09:13:34 (+0100) main 2021-11-23 08:13:34.106 [TCE:INFO] Infos: b827:ebff:fe09:fa6e muxs-::0 wss://192.168.43.199:8887/traffic/eui-B827EBFFFE09FA6E
23.11.21 09:13:34 (+0100) main 2021-11-23 08:13:34.106 [AIO:DEBU] [3] ws_close reason=1000
23.11.21 09:13:34 (+0100) main 2021-11-23 08:13:34.106 [AIO:DEBU] Echoing close - reason=1000
23.11.21 09:13:34 (+0100) main 2021-11-23 08:13:34.107 [AIO:ERRO] Recv failed: SSL - The peer notified us that the connection is going to be closed
23.11.21 09:13:34 (+0100) main 2021-11-23 08:13:34.107 [AIO:DEBU] [3] WS connection shutdown…
23.11.21 09:13:34 (+0100) main 2021-11-23 08:13:34.107 [any:INFO] ./lns-ttn/tc.trust:
23.11.21 09:13:34 (+0100) main basic constraints : CA=t2021-11-23 08:13:34.108 [AIO:INFO] tc has no cert configured - running server auth and client auth with token
23.11.21 09:13:34 (+0100) main 2021-11-23 08:13:34.116 [TCE:VERB] Connecting to MUXS…
23.11.21 09:13:34 (+0100) main 2021-11-23 08:13:34.352 [AIO:ERRO] [3] WS upgrade failed with HTTP status code: 403
23.11.21 09:13:34 (+0100) main 2021-11-23 08:13:34.352 [AIO:DEBU] [3] WS connection shutdown…
23.11.21 09:13:34 (+0100) main 2021-11-23 08:13:34.352 [TCE:VERB] Connection to MUXS closed in state 3
23.11.21 09:13:34 (+0100) main 2021-11-23 08:13:34.352 [TCE:INFO] INFOS reconnect backoff 10s (retry 1)
What am I doing wrong?
