I am getting errors when I tried the TTS V3 on SX1301 concentrator.
27.03.21 00:56:41 (+0000) main 2021-03-27 00:56:41.043 [TCE:INFO] INFOS reconnect backoff 60s (retry 6)
27.03.21 00:57:41 (+0000) main 2021-03-27 00:57:41.044 [any:ERRO] Parsing trust certificate: X509 - The CRT/CRL/CSR format is invalid, e.g. different type expected
27.03.21 00:57:41 (+0000) main 2021-03-27 00:57:41.044 [AIO:ERRO] tc trust certificates rejected by MBedTLS
27.03.21 00:57:41 (+0000) main 2021-03-27 00:57:41.044 [TCE:INFO] INFOS reconnect backoff 60s (retry 7)
27.03.21 00:58:41 (+0000) main 2021-03-27 00:58:41.047 [any:ERRO] Parsing trust certificate: X509 - The CRT/CRL/CSR format is invalid, e.g. different type expected
27.03.21 00:58:41 (+0000) main 2021-03-27 00:58:41.048 [AIO:ERRO] tc trust certificates rejected by MBedTLS
27.03.21 00:58:41 (+0000) main 2021-03-27 00:58:41.048 [TCE:INFO] INFOS reconnect backoff 60s (retry 8)
27.03.21 00:59:41 (+0000) main 2021-03-27 00:59:41.049 [any:ERRO] Parsing trust certificate: X509 - The CRT/CRL/CSR format is invalid, e.g. different type expected
27.03.21 00:59:41 (+0000) main 2021-03-27 00:59:41.049 [AIO:ERRO] tc trust certificates rejected by MBedTLS
27.03.21 00:59:41 (+0000) main 2021-03-27 00:59:41.049 [TCE:INFO] INFOS reconnect backoff 60s (retry 9)
27.03.21 01:00:41 (+0000) main 2021-03-27 01:00:41.052 [any:ERRO] Parsing trust certificate: X509 - The CRT/CRL/CSR format is invalid, e.g. different type expected
27.03.21 01:00:41 (+0000) main 2021-03-27 01:00:41.052 [AIO:ERRO] tc trust certificates rejected by MBedTLS
27.03.21 01:00:41 (+0000) main 2021-03-27 01:00:41.052 [TCE:INFO] INFOS reconnect backoff 60s (retry 10)
27.03.21 01:01:41 (+0000) main 2021-03-27 01:01:41.055 [any:ERRO] Parsing trust certificate: X509 - The CRT/CRL/CSR format is invalid, e.g. different type expected
27.03.21 01:01:41 (+0000) main 2021-03-27 01:01:41.055 [AIO:ERRO] tc trust certificates rejected by MBedTLS
27.03.21 01:01:41 (+0000) main 2021-03-27 01:01:41.055 [TCE:INFO] INFOS reconnect backoff 60s (retry 11)
@mpous Thanks for your reply. Its Beagle Bone Green with IMST iC880a concentrator. I did use the balenaHub to deploy the application on to my device. Happy to jump on a call if you like.
No change, errors still persist. May I ask, is SPI interface enabled in the image ? I cannot see spi devices in the file system under /dev. Could you please let me know ? @mpous
root@fd9f6b6:/usr/src/app# ls /dev/spidev0.0
ls: cannot access ‘/dev/spidev0.0’: No such file or directory
that’s odd as the SPI works on my side with Raspberry Pi 3 (which should be compatible with Beagle Bone Green) but i only tested this on Raspberry Pi. Could you please introduce an issue on the repository? I would like to find the solution for this! Thanks!
Hi Marc. I was having a problem with the certificates being rejected as outlined in the posts above and as this was my first time using BalenaOS I took the easy option of going back to Linux and compiling and building a Basics Station from source. I’m glad to say that this is connecting fine to Things Stack Community Edition successfully and my OTAA devices messages are being received. I’ve still got the BalenaOS setup on an SD card so I could give it a go and let you have the log if you want. Cheers.
I am also having the same problem. My basic station on RAK2245/RPi3B was working fine in Clare (using a Hotspot) but when I moved it 100 miles to Mayo I had the trust certificate issue.
Here’s my log:
02.06.21 16:03:53 (+0100) main 2021-06-01 14:28:15.271 [AIO:ERRO] tc trust certificates rejected by MBedTLS
02.06.21 16:03:53 (+0100) main 2021-06-01 14:28:15.271 [TCE:INFO] INFOS reconnect backoff 60s (retry 17)
02.06.21 16:04:53 (+0100) main 2021-06-01 14:29:15.272 [any:ERRO] Parsing trust certificate: X509 - The CRT/CRL/CSR format is invalid, e.g. different type expected
02.06.21 16:04:53 (+0100) main 2021-06-01 14:29:15.272 [AIO:ERRO] tc trust certificates rejected by MBedTLS
02.06.21 16:04:53 (+0100) main 2021-06-01 14:29:15.272 [TCE:INFO] INFOS reconnect backoff 60s (retry 18)
02.06.21 16:05:53 (+0100) main 2021-06-01 14:30:15.273 [any:ERRO] Parsing trust certificate: X509 - The CRT/CRL/CSR format is invalid, e.g. different type expected
Yep. And I moved a V2 basic station which also had the same issue when first powered up afterwards.
It’s also having same cert issue!!
02.06.21 16:53:14 (+0100) main 2021-06-02 15:17:42.399 [AIO:ERRO] tc trust certificates rejected by MBedTLS
02.06.21 16:53:14 (+0100) main 2021-06-02 15:17:42.399 [TCE:INFO] INFOS reconnect backoff 20s (retry 2)
02.06.21 16:53:34 (+0100) main 2021-06-02 15:18:02.400 [any:ERRO] Parsing trust certificate: X509 - The CRT/CRL/CSR format is invalid, e.g. different type expected
02.06.21 16:53:34 (+0100) main 2021-06-02 15:18:02.400 [AIO:ERRO] tc trust certificates rejected by MBedTLS
02.06.21 16:53:34 (+0100) main 2021-06-02 15:18:02.400 [TCE:INFO] INFOS reconnect backoff 30s (retry 3)
02.06.21 16:54:04 (+0100) main 2021-06-02 15:18:32.402 [any:ERRO] Parsing trust certificate: X509 - The CRT/CRL/CSR format is invalid, e.g. different type expected
02.06.21 16:54:04 (+0100) main 2021-06-02 15:18:32.402 [AIO:ERRO] tc trust certificates rejected by MBedTLS
02.06.21 16:54:04 (+0100) main 2021-06-02 15:18:32.402 [TCE:INFO] INFOS reconnect backoff 40s (retry 4)
So I choose “Restart” and in a minute is came up OK!
