Is it possible to connect a resin.io device to a network that requires username and password? I have wifi and Ethernet but both require a username and passoword.
Thanks for your help
Yes, it is possible by setting the appropriate NetworkManager settings. For an example on how to do this for wifi connectivity, you can check this guide: https://docs.resin.io/reference/resinOS/network/2.x/#wifi-setup
