Change wireless to wired connection
In preparing for the download, I selected “ethernet and wireless” and entered the ssid and passphrase of the router.
The Fold for Covid is uo and running on the RPi. I have just wired ethernet to the router, so the router has assigned IP addresses for both the wired and wireless connections. Not sure how or where to change the configuration to use ethernet-only.
Thanks for any help.
Hi @jpaik welcome to the forum and thanks for trying the project!
The easiest way to remove the wireless configuration at this point is to plug the SD card back into your computer, and look in the ‘system-connections’ folder. In there you’ll see a file called resin-wifi-01, if you delete this you should be back to wired-only access. :+1:
Thank you! I’ll try this.
