Hey, so the problem you’re hitting is that there aren’t any generic amd64 images to download, so there is no add device to download an image, instead it’s designed to be used for custom os builds that are amd64 compatible but not a directly support device. If you’re using a custom amd64 device but want to use a standard resin os image then your best option is probably to try an intel-nuc application, although I can’t guarantee it will work
thanks @_Page for the answer. we would like to use resin for our 36 kiosk device deployment, which is a industrial grade generic amd64 motherboard. what should we do? could you point us to any guide please how to use resin with a standard 64bit pc? thank you.
We are working on a generic x86 device type that should work on most x86 boards, we will release this image later this week or next week.
We will keep you posted.
Kind regards,
Theodor
After checking back on this with the respective team, it ends up that you should be using the Intel NUC device type for your x86-64 devices. A new release is also expected soon.
Give us a note if you face any issues in the process.
PS: The generic device type is used for dependent devices and does not offer image downloads.
