Cant able to flash Tails to USB Stick. When i try to flash its show some error.
Please help ion this Matter !! Please find below error !!
Hi, can you press CTRL - SHIFT - I and see if there are any errors in console tab?
Also, can you tell us what is “Tails” and where you got the image from?
Tails is a Live os you can find it through Google
Hi, after pressing CTRL SHIFT I , can you please show us the console tab and if possible copy & paste the contents instead of screenshot?
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react\cjs\react.development.js:315 Warning: React.createFactory() is deprecated and will be removed in a future major release. Consider using JSX or use React.createElement() directly instead.
printWarning @ C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\react\cjs\react.development.js:315
gui.js:3275 _____ _ _
| | | | | | ___ _ __
| || / | ’ \ / _ \ '|
_/ ____|| ||___||
Interested in joining the Etcher team?
Drop us a line at join+etcher@balena.io
Version = 1.5.89, Type = nsis
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\resin-corvus\src\resin-corvus.js:39 Fri May 22 2020 01:41:29 GMT+0530 (India Standard Time) Application start ({“packageType”:“nsis”,“version”:“1.5.89”,“sample”:0.1,“applicationSessionUuid”:“0c0fa7e2-c9c6-4121-9338-ed5ac27fbbad”,“flashingWorkflowUuid”:“696be426-a836-4a91-96f1-4281a85a485d”})
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Fri May 22 2020 01:41:36 GMT+0530 (India Standard Time) Open image selector ({“sample”:0.1,“applicationSessionUuid”:“0c0fa7e2-c9c6-4121-9338-ed5ac27fbbad”,“flashingWorkflowUuid”:“696be426-a836-4a91-96f1-4281a85a485d”})
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Fri May 22 2020 01:41:49 GMT+0530 (India Standard Time) Select image ({“image”:{“size”:1194328064,“name”:“tails-amd64.ISO.img”,“hasMBR”:true,“partitions”:[{“offset”:1048576,“size”:1192230912,“type”:“C12A7328-F81F-11D2-BA4B-00A0C93EC93B”,“guid”:“34BF027A-8001-4B93-8243-1F9D3DCE7DE7”,“name”:“Tails”,“index”:1}],“path”:“C:\Users\KARTHIK\Downloads\tails-amd64.ISO.img”,“extension”:“img”,“logo”:false,“blockMap”:false},“sample”:0.1,“applicationSessionUuid”:“0c0fa7e2-c9c6-4121-9338-ed5ac27fbbad”,“flashingWorkflowUuid”:“696be426-a836-4a91-96f1-4281a85a485d”})
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Fri May 22 2020 01:41:51 GMT+0530 (India Standard Time) Flash ({“image”:“C:\Users\KARTHIK\Downloads\tails-amd64.ISO.img”,“drives”:[{“size”:15938355200,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:"\\.\PhysicalDrive1",“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:,“description”:“Generic Flash Disk USB Device”,“isUAS”:false}],“driveCount”:1,“uuid”:“f2347f92-30fc-459b-b86f-1fa73a7194af”,“status”:“started”,“flashInstanceUuid”:“f2347f92-30fc-459b-b86f-1fa73a7194af”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“sample”:0.1,“applicationSessionUuid”:“0c0fa7e2-c9c6-4121-9338-ed5ac27fbbad”,“flashingWorkflowUuid”:“696be426-a836-4a91-96f1-4281a85a485d”})
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Elevating command: C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\balenaEtcher.exe C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\lodash\lodash.js:10333 0 devices, 0% at 0.00 MB/s (total 0.00 MB/s) with 0 failed devices
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Fri May 22 2020 01:41:52 GMT+0530 (India Standard Time) SafeWebview loaded ({“event”:{“id”:1,“url”:“https://assets.balena.io/etcher-featured/index.html?etcher-version=1.5.89&api-version=2&optOutAnalytics=false",“method”:“GET”,“timestamp”:1590091912953.253,“resourceType”:“mainFrame”,“ip”:“104.31.82.157”,“fromCache”:false,“statusLine”:"HTTP/1.1 200”,“statusCode”:200,“responseHeaders”:{“access-control-allow-origin”:[""],“age”:[“0”],“cache-control”:[“max-age=600”],“cf-cache-status”:[“DYNAMIC”],“cf-ray”:[“5970f2f7ba7adf77-BOM”],“cf-request-id”:[“02da762ecf0000df77a8b6a200000001”],“content-encoding”:[“br”],“content-type”:[“text/html; charset=utf-8”],“date”:[“Thu, 21 May 2020 20:11:53 GMT”],“expect-ct”:[“max-age=604800, report-uri=“https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct””],“expires”:[“Thu, 21 May 2020 11:40:23 GMT”],“last-modified”:[“Thu, 21 May 2020 10:54:28 GMT”],“server”:[“cloudflare”],“status”:[“200”],“vary”:[“Accept-Encoding”],“via”:[“1.1 varnish”],“x-cache”:[“HIT”],“x-cache-hits”:[“1”],“x-fastly-request-id”:[“cde323486cfae09dd38b3aa5ba139aa5241fb5a5”],“x-github-request-id”:[“66E4:6F3B:14483A:16C46B:5EC6664E”],“x-origin-cache”:[“1”],“x-proxy-cache”:[“MISS”],“x-served-by”:[“cache-bom18222-BOM”],“x-timer”:[“S1590091913.031098,VS0,VE188”]},“webContentsId”:2,“referrer”:"",“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“0c0fa7e2-c9c6-4121-9338-ed5ac27fbbad”,“flashingWorkflowUuid”:“696be426-a836-4a91-96f1-4281a85a485d”})
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Successfully connected to IPC server: etcher-server-2168, socket root C:\Users\KARTHIK\AppData\Local\Temp
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Image: C:\Users\KARTHIK\Downloads\tails-amd64.ISO.img
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Devices: \.\PhysicalDrive1
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Umount on success: true
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Validate on success: true
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Auto blockmapping: true
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Decompress first: true
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Terminating IPC server
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Flash results Object
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Fri May 22 2020 01:42:02 GMT+0530 (India Standard Time) Write failed ({“image”:“C:\Users\KARTHIK\Downloads\tails-amd64.ISO.img”,“drives”:[{“size”:15938355200,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:"\\.\PhysicalDrive1",“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[],“description”:“Generic Flash Disk USB Device”,“isUAS”:false}],“driveCount”:1,“uuid”:“f2347f92-30fc-459b-b86f-1fa73a7194af”,“status”:“failed”,“flashInstanceUuid”:“f2347f92-30fc-459b-b86f-1fa73a7194af”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“error”:{“description”:“Please try again, and contact the Etcher team if the problem persists”,“report”:false,“code”:“ECHILDDIED”},“sample”:0.1,“applicationSessionUuid”:“0c0fa7e2-c9c6-4121-9338-ed5ac27fbbad”,“flashingWorkflowUuid”:“696be426-a836-4a91-96f1-4281a85a485d”})
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Fri May 22 2020 01:42:17 GMT+0530 (India Standard Time) Open image selector ({“sample”:0.1,“applicationSessionUuid”:“0c0fa7e2-c9c6-4121-9338-ed5ac27fbbad”,“flashingWorkflowUuid”:“696be426-a836-4a91-96f1-4281a85a485d”})
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Fri May 22 2020 01:42:21 GMT+0530 (India Standard Time) Select image ({“image”:{“size”:1194328064,“name”:“tails-amd64-4.6 (1).img”,“hasMBR”:true,“partitions”:[{“offset”:1048576,“size”:1192230912,“type”:“C12A7328-F81F-11D2-BA4B-00A0C93EC93B”,“guid”:“34BF027A-8001-4B93-8243-1F9D3DCE7DE7”,“name”:“Tails”,“index”:1}],“path”:“C:\Users\KARTHIK\Downloads\tails-amd64-4.6 (1).img”,“extension”:“img”,“logo”:false,“blockMap”:false},“sample”:0.1,“applicationSessionUuid”:“0c0fa7e2-c9c6-4121-9338-ed5ac27fbbad”,“flashingWorkflowUuid”:“696be426-a836-4a91-96f1-4281a85a485d”})
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Fri May 22 2020 01:42:26 GMT+0530 (India Standard Time) Toggle drive ({“drive”:{“size”:15938355200,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:"\\.\PhysicalDrive1",“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[],“description”:“Generic Flash Disk USB Device”,“isUAS”:false},“previouslySelected”:false,“sample”:0.1,“applicationSessionUuid”:“0c0fa7e2-c9c6-4121-9338-ed5ac27fbbad”,“flashingWorkflowUuid”:“696be426-a836-4a91-96f1-4281a85a485d”})
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Fri May 22 2020 01:42:30 GMT+0530 (India Standard Time) Flash ({“image”:“C:\Users\KARTHIK\Downloads\tails-amd64-4.6 (1).img”,“drives”:[{“size”:15938355200,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:"\\.\PhysicalDrive1",“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[],“description”:“Generic Flash Disk USB Device”,“isUAS”:false}],“driveCount”:1,“uuid”:“71f006b8-6786-4579-9186-4dbf84bed1d8”,“status”:“started”,“flashInstanceUuid”:“71f006b8-6786-4579-9186-4dbf84bed1d8”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“sample”:0.1,“applicationSessionUuid”:“0c0fa7e2-c9c6-4121-9338-ed5ac27fbbad”,“flashingWorkflowUuid”:“696be426-a836-4a91-96f1-4281a85a485d”})
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Fri May 22 2020 01:42:30 GMT+0530 (India Standard Time) SafeWebview loaded ({“event”:{“id”:19,“url”:“https://assets.balena.io/etcher-featured/index.html?etcher-version=1.5.89&api-version=2&optOutAnalytics=false",“method”:“GET”,“timestamp”:1590091950820.54,“resourceType”:“mainFrame”,“ip”:“104.31.82.157”,“fromCache”:false,“statusLine”:"HTTP/1.1 200”,“statusCode”:200,“responseHeaders”:{“access-control-allow-origin”:[""],“age”:[“38”],“cache-control”:[“max-age=600”],“cf-cache-status”:[“DYNAMIC”],“cf-ray”:[“5970f3e7aeabe139-BOM”],“cf-request-id”:[“02da76c4c90000e1390f9f5200000001”],“content-encoding”:[“br”],“content-type”:[“text/html; charset=utf-8”],“date”:[“Thu, 21 May 2020 20:12:31 GMT”],“expect-ct”:[“max-age=604800, report-uri=“https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct””],“expires”:[“Thu, 21 May 2020 11:40:23 GMT”],“last-modified”:[“Thu, 21 May 2020 10:54:28 GMT”],“server”:[“cloudflare”],“status”:[“200”],“vary”:[“Accept-Encoding”],“via”:[“1.1 varnish”],“x-cache”:[“HIT”],“x-cache-hits”:[“1”],“x-fastly-request-id”:[“4ad1386aca09c6c99aa1bddb058d90d77d25ad6c”],“x-github-request-id”:[“66E4:6F3B:14483A:16C46B:5EC6664E”],“x-origin-cache”:[“1”],“x-proxy-cache”:[“MISS”],“x-served-by”:[“cache-bom18223-BOM”],“x-timer”:[“S1590091951.372137,VS0,VE1”]},“referrer”:"",“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“0c0fa7e2-c9c6-4121-9338-ed5ac27fbbad”,“flashingWorkflowUuid”:“696be426-a836-4a91-96f1-4281a85a485d”})
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Image: C:\Users\KARTHIK\Downloads\tails-amd64-4.6 (1).img
C:\Users\KARTHIK\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58 Fri May 22 2020 01:42:36 GMT+0530 (India Standard Time) Write failed ({“image”:“C:\Users\KARTHIK\Downloads\tails-amd64-4.6 (1).img”,“drives”:[{“size”:15938355200,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:"\\.\PhysicalDrive1",“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:,“description”:“Generic Flash Disk USB Device”,“isUAS”:false}],“driveCount”:1,“uuid”:“71f006b8-6786-4579-9186-4dbf84bed1d8”,“status”:“failed”,“flashInstanceUuid”:“71f006b8-6786-4579-9186-4dbf84bed1d8”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“error”:{“description”:“Please try again, and contact the Etcher team if the problem persists”,“report”:false,“code”:“ECHILDDIED”},“sample”:0.1,“applicationSessionUuid”:“0c0fa7e2-c9c6-4121-9338-ed5ac27fbbad”,“flashingWorkflowUuid”:“696be426-a836-4a91-96f1-4281a85a485d”})
Hey,
Sometimes in windows you need to run Etcher as an administrator. Right click the app, click run as administrator and flash from there.
Let us know if that works!
Lucy-Jane
