I’ve followed instructions to try and install BalenaOS on nVidia Jetson TX1. Everything is fine until the point where the device needs to be provisioned. I put the SDCard with the BalenaOS in the device and poweron. The device boots up, and connects to the balena cloud (it says device is provisioning, and then copying from sdcard to internal storage). Afterwards the device shuts down as expected, but when I remove the SDcard and perform a restart the device doesn’t boot anymore. (balena cloud says device is in post provisioning).
The only way to recover is to put device in recovery mode and reinstall everything using JetPack.
Any help to diagnose or solve this issue will be much appreciated.
Regards,
