I’ve got a Jetson TX2 Dev board from NVIDIA that I’m trying to use to test the Balena service. I added a device via the cloud interface, and downloaded a development BalenaOS image, called “balena-cloud-jetson-tx2-2.69.1+rev4-dev-v12.3.5”
I flashed this to an SD card using BalenaEtcher. I wiped my TX2 board and installed a L4T 32.3.1 image. I booted the TX2 with the card inserted, and the initial boot appeared to work; I saw a bunch of BalenaOS-related systemd messages, it ran for a couple minutes, then powered itself off. I removed the SD card. I turned the TX2 back on. I saw an all-white boot logo, which was replaced by a console. I’m now looking at a white screen with a turquoise Balena logo.
It’s been sitting like this for maybe 20 minutes so far. I’m logged into my dashboard at balena dashboard but I haven’t seen any indication that provisioning is taking place.
Is there a way to troubleshoot? I logged in as root on vt2 and confirmed that there’s network access, including DNS resolution. systemd shows no degraded services.
