I’m working on a system I haven’t touched in a few months and I’m struggling to push my changes to resin. Everytime I push I fail to fetch the base image. My internet is working, I can push to my normal repository, and changing my base image doesn’t seem to help. I’ve tried doing some debugging around the internet and this doesn’t seem to be a common issue, does anyone have any suggestions?
Below is a copy of the error I get:
Counting objects: 32, done.
Delta compression using up to 2 threads.
Compressing objects: 100% (32/32), done.
Writing objects: 100% (32/32), 2.93 KiB | 0 bytes/s, done.
Total 32 (delta 19), reused 0 (delta 0)
[Info] Starting build for sam1/qawma, user sam1
[Info] Dashboard link: https://dashboard.resin.io/apps/506028/devices
[Info] Building on ARM01
[Info] Pulling old image for caching purposes
[=========================> ] 50%[Info] Fetching base image
[Error] Could not fetch base image: resin/raspberrypi-debian:jessie
