Error on git push resin
Hi, I’m having issue here trying to do a git push resin master:
Counting objects: 10, done.
Delta compression using up to 4 threads.
Compressing objects: 100% (8/8), done.
Writing objects: 100% (10/10), 874 bytes | 0 bytes/s, done.
Total 10 (delta 2), reused 0 (delta 0)
[Info]     Starting build for adrian_sanchez/mytest, user adrian_sanchez
[Info]     Dashboard link: https://dashboard.resin.io/apps/460134/devices
[Info]     Building on ARM01
[Info]     Pulling old image for caching purposes
[==================================================>] 100%
[Success]  Cached image pulled in 2 seconds
[Info]     Fetching base image
[Warning]  No image tag given for demosense/resin-deploy-compose, using default (latest)
[Info]     Building Standard Dockerfile project
[Build]    Step 1/2 : FROM demosense/resin-deploy-compose
[Build]     ---> 0eaa70b6b8a1
[Build]    Step 2/2 : COPY apps /apps
[Build]     ---> 2b66287612b4
[Build]    Removing intermediate container d55adc2c6e4a
[Build]    Successfully built 2b66287612b4
[Build]    Successfully tagged registry2.resin.io:443/mytest/deca0010795059f5ea3db94d35483a5b4e75ae09:latest
[Success]  Image created successfully
[Info]     Verifying image integrity...
[Success]  Image passed integrity checks!
[Info]     Uploading image to registry...
[Info]     Still working...
[=========================>                         ] 50%[Info]     Still working...
[=========================>                         ] 50%[Error]    Build failed: denied: requested access to the resource is denied
To adrian_sanchez@git.resin.io:adrian_sanchez/mytest.git
 ! [remote rejected] master -> master (hook declined)
error: failed to push some refs to 'adrian_sanchez@git.resin.io:adrian_sanchez/mytest.git'
I tried this many many times, and I always get the same error (it takes a couple of minutes stuck in 50% uploading the image).
The thing is this same push of the same app and repository was working correctly before (hours earlier), now it doesn’t anymore.
I think there it might be an error on your server side. Any ideas?
We are seeing some API / builder issues at the moment and are currently investigating, http://status.resin.io/
Hi @adrian, the issue should be resolved now and the builds should work fine again! Let us know if you run into anything else (hopefully nothing else).
