Build server not correctly determining that application has a succeeded release
Ok so here is the error message I’m getting when trying to build for any application right now:
[Error]    An error occured: It is necessary that each application that has a commit1 and owns at least 1 release that has a commit2 that is equal to the commit1, owns a release that has a commit3 that is equal to the commit1 and has a status that is equal to "success".
[Error]    Not deploying release.
[Error]    Upstream API server/DB error:
Apart from the weirdly written error, I assume that this means every application must have a release with the same commit hash as is currently deployed that succeeded? I think this could be written much clearer for an end-user but ok, its technical its fine.
The real issue is that this is not true. There is a release on the application that has the same commit as the currently deployed commit and that is shown as succeeded in the balenaCloud interface, the implication being that I am not able to update the device:
Hi, we had a brief outage with our git service but that should be resolved now. Can you try the push again? Thanks.
I see, works fine again, thank you :slight_smile:
