Git push reports "An error occurred: ESOCKETTIMEDOUT"
We are seeing the following error one all our projects:
[Error]    An error occurred: ESOCKETTIMEDOUT
[Error]    Not deploying release.
To git.balena-cloud.com:<user>/<project>.git
 ! [remote rejected] HEAD -> master (hook declined)
error: failed to push some refs to '<user>@git.balena-cloud.com:<user>/<project>.git'
According to status.balena.io everything seems to be ok.
Is this a known issue or did we break something in our user / projects?
Hi there,
The issue was just reported on the status page, we are currently experiencing problems with the builder servers and are handling the issue. I will let you know when everything is back to normal.
The builders should be back to normal now.
Hi @sradevski
I’m getting this error today quite frequently. Are there any issues?
Fritz
Also getting this error.
me too!
Did it work??
Hi folks, there was a Builder Outage last night that caused these errors…We’ll have some more info on http://status.balena.io as we post-mortem. In the meantime, if you try again, you should be able to deploy now. Thanks!
Thank You! Able to deploy now
