I just upgraded Belenaetcher to the current version (v1.5.104) and used it to write a Pine64Pro image to an eMMC. The Pine64 USB stick was plugged into my USB3 hub. Everything went pretty much as expected, until the very end. It finished verifying then said it was ejecting the image, and then I got a BSOD.
It took some doing, but I figured out the minidump tool enough to get it to output the following:
Loading Dump File [r:\082520-13843-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 19041 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 19041.1.amd64fre.vb_release.191206-1406
Machine Name:
Kernel base = 0xfffff802`1be00000 PsLoadedModuleList = 0xfffff802`1ca2a2f0
Debug session time: Tue Aug 25 03:36:29.013 2020 (UTC - 4:00)
System Uptime: 13 days 13:10:41.506
... Lots of addresses and stuff elided...
* Bugcheck Analysis *
FAT_FILE_SYSTEM (23)
If you see FatExceptionFilter on the stack then the 2nd and 3rd
parameters are the exception record and context record. Do a .cxr
on the 3rd parameter and then kb to obtain a more informative stack
trace.
Arguments:
Arg1: 00000000000e0121
Arg2: ffff908edb27c6e8
Arg3: ffff908edb27bf20
Arg4: fffff8021f14f403
Debugging Details:
BUGCHECK_CODE: 23
BUGCHECK_P1: e0121
BUGCHECK_P2: ffff908edb27c6e8
BUGCHECK_P3: ffff908edb27bf20
BUGCHECK_P4: fffff8021f14f403
PROCESS_NAME: balenaEtcher.exe
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%p referenced memory at 0x%p. The memory could not be %s.
SYMBOL_NAME: volmgr!VmpQueryUniqueIdInternal+37
MODULE_NAME: volmgr
IMAGE_NAME: volmgr.sys
FAILURE_BUCKET_ID: 0x23_volmgr!VmpQueryUniqueIdInternal
FAILURE_ID_HASH: {d0e2cbbb-f6c9-659f-dade-4145ab43ee0a}
Followup: MachineOwner
Finished dump check
Since nothing on my system is using FAT as far as I know, this was a slightly strange event to me… I’m guessing maybe the system was in the process of trying to make sense of the newly formatted eMMC filesystem when the eject occurred and it really wasn’t happy with the result…?
