Boot image from USB
Hi there, is it possible to flash a resin.io image onto a USB key and boot from it? The idea would be to flash an IntelNuc app to USB and boot from it on a Mac or Windows computer,.
Hi @brice that is not currently possible directly, but there might be a way to work around it (extracting the image the flasher flashes, and get that on the USB key, run from there). Will check it out and update it here with the results. Will also open an internal ticket for this feature request.
Thanks @imrehg
Would be good to have something like the raspberrypi image where you can run of the SD-Card and no flashing is involved, is there a setting in the IntelNuc image to disable the flashing and just boot?
