After programming my 2 boards 1 is unable to recognise the 16GB storage on the Balenafin board. When plugged into the balenafin program it only shows 32.1 MB of storage.
Working boards kernal messages
[ 3467.738371] usb 1-6: Manufacturer: Raspberry Pi
[ 3467.738373] usb 1-6: SerialNumber: e858bf15
[ 3467.739745] usb-storage 1-6:1.0: USB Mass Storage device detected
[ 3467.740345] scsi host0: usb-storage 1-6:1.0
[ 3468.754236] scsi 0:0:0:0: Direct-Access RPi-MSD- 0001 PQ: 0 ANSI: 2
[ 3468.755125] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 3468.755460] sd 0:0:0:0: [sda] 30777344 512-byte logical blocks: (15.8 GB/14.7 GiB)
[ 3468.755700] sd 0:0:0:0: [sda] Write Protect is off
[ 3468.755704] sd 0:0:0:0: [sda] Mode Sense: 0f 00 00 00
[ 3468.755857] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 3468.777907] sda: sda1 sda2
[ 3468.780236] sd 0:0:0:0: [sda] Attached SCSI removable disk
Faulty boards kernal messages
[ 1767.140358] usb 1-6: Product: Compute Module
[ 1767.140358] usb 1-6: Manufacturer: Raspberry Pi
[ 1767.140359] usb 1-6: SerialNumber: e72efe1f
[ 1767.692172] usb-storage 1-6:1.0: USB Mass Storage device detected
[ 1767.692971] scsi host0: usb-storage 1-6:1.0
[ 1767.693068] usbcore: registered new interface driver usb-storage
[ 1767.694425] usbcore: registered new interface driver uas
[ 1768.724558] scsi 0:0:0:0: Direct-Access RPi-MSD- 0001 PQ: 0 ANSI: 2
[ 1768.725286] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1768.725790] sd 0:0:0:0: [sda] 62688 512-byte logical blocks: (32.1 MB/30.6 MiB)
[ 1768.725998] sd 0:0:0:0: [sda] Write Protect is off
[ 1768.726002] sd 0:0:0:0: [sda] Mode Sense: 0f 00 00 00
[ 1768.726165] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 1768.754193] sd 0:0:0:0: [sda] Attached SCSI removable disk
