Blank screen on Mac OS 11.2.3
Hi all - wanted to let you know about an issue I found and a resolution.
On an M1 Mac running 11.2.3 with Etcher 1.5.120, doing the following produces a blank screen:
  1. Open Etcher
  2. Click select image button
  3. Find file and select it
  4. Blank screen results
Nothing can be done at this point. I tried with the SD card reader detached and same results.
Running it under Rosetta emulation appears to fix it and I was able to successfully flash an SD card.
Just in case someone else comes across this issue and needs a workaround.
Hi, thanks for letting us know about this issue. Can you please post the console logs in the dev tools?
Cmd+Opt+I → Click Console → Copy text from the console and paste it here.
otherwise it’s hard to know what’s going wrong exactly. If you could post a screenshot too, that would be excellent.
We definitely want to get this resolved as quickly as possible as the M1 chips become more and more common!
Not a lot, looks like it instnatly disconnects from Dev Tools
  1. Opened balenaEtcher
  2. Either, pick a file or use a url
  3. Click ok
  4. White screen
Same issue here.
This worked!
Thank you!
To run an app in Rosetta
*quit any open instances of the application
then
  1. Locate the app in finder
  2. command - i or alternative click and select get info
  3. select the check box to open in Rosetta
  4. run the app
Great! Thanks for letting us know!
