Hi
This is my first time using balena, so sorry if this is very rudamental.
I have a setup with a Raspberry Pi Zero W and a Pirate Audio DAC 3w amplifier.
I have got the system up and running, and can connect with both airplay and spotify, but i’m getting no audio out.
Under Device variables i have changed Audio out to DAC and under Device configuration → Definee DT Overlays i have added “BALENA_HOST_CONFIG_dtoverlay=hifiberry-dac”
Any Ideas on why i’m getting no audio out?
After reeding the log more carefully, it seems like the DAC is not discovered, running aplay -L gives me the following:
bash-5.0# aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
pulse
PulseAudio Sound Server
default
Default ALSA Output (currently PulseAudio Sound Server)
sysdefault:CARD=bcm2835-alsa
bcm2835 ALSA, bcm2835 ALSA
Default Audio Device
So it this a config thing or a hardware thing?
Hi
Does this device require external power or something? It would be nice to rule out any issues with the hardware connections.
Can you perhaps share a photo of your connections?
Hi Anuj, thanks for the reply.
After getting a bit annoyed yesterday i built a new image with mopidy, and with mopidy everything is working smoothly and audio is coming out. Mopidy on the other hand doesnt give me the functionality i want, so i will go back to Balena.
But, as everything work fine with mopidy im quite confident the hardware is working as it should.
So: no, externa power is not required, and i am powering it with a 3A charger, so the power should be more than enough.
Hi Thomas, I just checked the Pirate Audio DAC 3w amplifier documentation and found this which looks very interesting:
There is a DAC enable pin—BCM 25— that must be driven high to enable the DAC. You can do this by adding gpio=25=op,dh to the /boot/config.txt file.
Probably mopidy’s image is taking care of this while I’m sure we are not. I suspect the DAC is “offline” without that pin being driven high so that’s why it’s not being listed. It’s the first time I see a DAC that needs this, it might be it has this option to reduce power consumption, not really sure.
Anyways, there are two ways you can try this:
- edit
config.txt on your SD card
- apply the config remotely using a configuration variable:
BALENA_HOST_CONFIG_gpio with a value of 25=op,dh
Let me know how this goes, if it does we’ll need to update our docs to include this special case.
Got it back to balena now, and that fix worked perfetcly, thanks
And yes, that is thee correct DAC.
