I am trying to setup a brand new Banana Pi M1+ onto Balena. I have several Raspberry Pis in other fleets, on the same network, that are fully connected.
However the Banana Pi, connects, but never establishes its VPN into Balena.
Using the Local Balena SSH I was able to get in and run the systemctl status for openvpn, and see this error.
This appears to be even before any code or containers that I would be deploying to it, is there a problem with the certs? Is this something I can fix?
EDIT:
Also just to clarify, I am not using openBalena or anything, this is the normal hosted Balena.
I did try re-flashing to a new SD card, but I only have one of the physical devices. Both instances only ever get to ‘Heartbeat’ only. If I deploy code, it runs just fine and I can locally get to it, but I cann ot use any of the functions that need the VPN, like the Public Device URL.
Hi, could you share the output of the commands journalctl -u openvpn -xef and openvpn --version on your bananaPi device? This is quite an old OS version and we have seen some issues with openvpn compatibility, before, but having some extra logs might help determine the cause.
If you guys need me to open this one up for Remote Support somehow, I am more than willing to. I understand that the nature of the problem is that its not hitting the VPN, so I can setup another device on the same network that IS (like a Raspberry Pi) and allow you guys to get in that way if needed.
Sorry for hijacking the thread, but I’m also having issues with BananaPI. I’m trying to use the supervisor API, but since Banana’s supervisor is still in version 7, it won’t work with my script. The OS is still 2.12.
I cannot see anything obvious that explains the problem on the logs. My first instinct is that this could be a time synchronization issue, but we would need more testing to confirm.
One thing you could both try is the following.
We publish our test images in our staging site balena-staging.com and I see there are newer OS images (2.46.1) for the bananaPI M1+. You can download one of the images from that site and then configure it to run against balena-cloud using the balena os configure command from our CLI.
If the VPN / missing supervisor endpoints persist, we can take it from there.
I also wanted to let you know that we are working on improvements to our OS deployment process so soon device type images will be created much faster after a OS changes are published. We have no hard ETA on this feature, but the improvements are being actively worked on.
