Hi there!
I am trying to set up Balena sound on my Pi 3B+ and I need your help =). I installed BalenaSound using the simple deploy button from the webpage. Everything seems fine, all services are running, but there is no sound. I tried the 3.5 mm headphone jack using the standard configurations and changing the AUDIO output variable to “RPI_HEADPHONES”. I also tried adding the device using the Raspberry PI 3 and Rasperry PI 3 (64bit) device options. I put the last log down below. My best guess would be that pulseaudio 15.0 has problems with the Pi 3B+ audio card? If you need more information please let me know!
Thanks guys!
multi-room_falling-brook-2025-04-05t20_50_56+02_00.txt (92.7 KB)
Edit: I managed to make it work using the 32 bit device type and downgrading the OS version to balenaOS 4.1.3+rev2. Still getting error messages from Pulseaudio but it works. See the logs below:
multi-room_rpi 3b±2025-04-06t10_23_15+02_00.txt (81.3 KB)
Have a nice weekend everyone!
