Hello,
I’m glad to help you get this set up! It sounds like you have balenaOS running on your Pi, so the next step is to deploy the balenaSound application on to your device. You can use the “Deploy with Balena” button (at the bottom of this page: https://sound.balenalabs.io/docs/) which is easiest, or install the CLI and push it yourself. Did you already perform one of those steps? Does the “current release” on your device’s page show “Factory build” or an ID?
