BalenaOS flash to eMMC support - RK3599
To whom it may concern,
We have a custom board that has a rockchip 3599 (using u-boot) and it only supports flashing to the eMMC (no ssd or sd card support, we can only use USB connection from pc to board). Can we adapt balenaOS build (we are starting with a generic-aarch64 build) in some way that allows flash to the device? The image must already contain all definition of boot, filesystem, etc. We are using the RKDevTool, DriverAssistent, to flash the device and just by using the image as generated, it does not work.
Best regards,
