for our application, it is not possible to use a SD card. So is it possible to flash the image to the internal eMMC of the Jetson TX2? I found that the meta-tegra layer supports generating a flash script (https://github.com/madisongh/meta-tegra/wiki/Flashing-the-Jetson-Dev-Kit) but is does not seem to work with balena. No flash script is generated. So, is there any chance to run balena os from eMMC?
Markus
