@alexgg cont …
Boot Log :
U-Boot SPL 2017.07 (Apr 09 2020 - 16:23:58)
Returning to boot ROM...
U-Boot 2017.07 (Apr 09 2020 - 16:23:58 +0000)
Model: Firefly-RK3288
DRAM: 2 GiB
MMC: dwmmc@ff0c0000: 1, dwmmc@ff0f0000: 0
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
Scanning mmc devices 0 1 2
reading resin-image-flasher
** Unable to read file resin-image-flasher **
reading resin-image
24 bytes read in 4 ms (5.9 KiB/s)
Card did not respond to voltage select!
mmc_init: -95, time 119
** Bad device mmc 1 **
** Bad device mmc 2 **
Found resin image on mmc 0
Loading resinOS_uEnv.txt from mmc device 0 partition 1
reading resinOS_uEnv.txt
** Unable to read file resinOS_uEnv.txt **
reading zImage
11771280 bytes read in 1291 ms (8.7 MiB/s)
reading firefly-rk3288.dtb
37798 bytes read in 9 ms (4 MiB/s)
## Flattened Device Tree blob at 01f00000
Booting using the fdt blob at 0x1f00000
Loading Device Tree to 0fff3000, end 0ffff3a5 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x500
[ 0.000000] Linux version 4.12.0-yocto-standard (oe-user@oe-host) (gcc version 7.3.0 (GCC) ) #1 SMP Thu Apr 9 14:42:03 UTC 2020
[ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Firefly-RK3288
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 64 MiB at 0x7c000000
[ 0.000000] percpu: Embedded 17 pages/cpu @eed94000 s39116 r8192 d22324 u69632
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522560
[ 0.000000] Kernel command line: root=PARTUUID=e004965c-02 rw rootfstype=ext4 rootwait console=tty1 console=ttyS2,115200n8
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1984340K/2097152K available (11264K kernel code, 1522K rwdata, 4248K rodata, 9216K init, 416K bss, 47276K reserved, 65536K cma-reserved, 1245184K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0208000 - 0xc0e00000 (12256 kB)
[ 0.000000] .init : 0xc1300000 - 0xc1c00000 (9216 kB)
[ 0.000000] .data : 0xc1c00000 - 0xc1d7caf0 (1523 kB)
[ 0.000000] .bss : 0xc1d862bc - 0xc1dee3a0 ( 417 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU debugfs-based tracing is enabled.
[ 0.000000] RCU restricting CPUs from NR_CPUS=16 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000022] Switching to timer-based delay loop, resolution 41ns
[ 0.004729] Console: colour dummy device 80x30
[ 0.005303] console [tty1] enabled
[ 0.005347] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.005396] pid_max: default: 32768 minimum: 301
[ 0.005530] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.005562] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.006229] CPU: Testing write buffer coherency: ok
[ 0.006507] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.007072] Setting up static identity map for 0x300000 - 0x3000a0
[ 0.011466] EFI services will not be available.
[ 0.011780] smp: Bringing up secondary CPUs ...
[ 0.013466] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.015220] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.016969] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.017070] smp: Brought up 1 node, 4 CPUs
[ 0.017161] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.017185] CPU: All CPU(s) started in SVC mode.
[ 0.018588] devtmpfs: initialized
[ 0.028952] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.029364] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.029419] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.031471] pinctrl core: initialized pinctrl subsystem
[ 0.033454] NET: Registered protocol family 16
[ 0.035735] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.038093] cpuidle: using governor menu
[ 0.038771] No ATAGs?
[ 0.038905] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.038966] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.041762] Serial: AMBA PL011 UART driver
[ 0.100948] AT91: Could not find identification node
[ 0.102627] vcc_5v: supplied by vcc_sys
[ 0.103174] vcc_host_5v: supplied by vcc_5v
[ 0.103678] vcc_otg_5v: supplied by vcc_5v
[ 0.107718] iommu: Adding device ff930000.vop to group 0
[ 0.107827] iommu: Adding device ff940000.vop to group 1
[ 0.108845] vgaarb: loaded
[ 0.109789] SCSI subsystem initialized
[ 0.110317] usbcore: registered new interface driver usbfs
[ 0.110408] usbcore: registered new interface driver hub
[ 0.110531] usbcore: registered new device driver usb
[ 0.112279] pps_core: LinuxPPS API ver. 1 registered
[ 0.112307] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.112366] PTP clock support registered
[ 0.112600] EDAC MC: Ver: 3.0.0
[ 0.115090] clocksource: Switched to clocksource arch_sys_counter
[ 0.178512] NET: Registered protocol family 2
[ 0.179113] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.179225] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.179434] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.179545] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.179612] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.179809] NET: Registered protocol family 1
[ 0.180196] RPC: Registered named UNIX socket transport module.
[ 0.180226] RPC: Registered udp transport module.
[ 0.180251] RPC: Registered tcp transport module.
[ 0.180274] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.236409] hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counters available
[ 0.238817] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 0.249278] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.249869] NFS: Registering the id_resolver key type
[ 0.249912] Key type id_resolver registered
[ 0.249937] Key type id_legacy registered
[ 0.251856] bounce: pool size: 64 pages
[ 0.251926] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.251967] io scheduler noop registered
[ 0.251992] io scheduler deadline registered
[ 0.252046] io scheduler cfq registered (default)
[ 0.252073] io scheduler mq-deadline registered
[ 0.252097] io scheduler kyber registered
[ 0.280370] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.280421] dma-pl330 ff250000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.281229] dma-pl330 ffb20000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.281278] dma-pl330 ffb20000.dma-controller: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 0.349485] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.351965] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A
[ 0.353010] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 39, base_baud = 1500000) is a 16550A
[ 0.354096] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 40, base_baud = 1500000) is a 16550A
[ 1.113688] console [ttyS2] enabled
[ 1.118636] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 41, base_baud = 1500000) is a 16550A
[ 1.130421] SuperH (H)SCI(F) driver initialized
[ 1.136804] msm_serial: driver initialized
[ 1.141648] STMicroelectronics ASC driver initialized
[ 1.168203] brd: module loaded
[ 1.179760] loop: module loaded
[ 1.194108] libphy: Fixed MDIO Bus: probed
[ 1.199999] tun: Universal TUN/TAP device driver, 1.6
[ 1.205892] CAN device driver interface
[ 1.211317] bgmac_bcma: Broadcom 47xx GBit MAC driver loaded
[ 1.219400] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.225972] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.232669] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.240487] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.249838] rk_gmac-dwmac ff290000.ethernet: PTP uses main clock
[ 1.256640] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing
[ 1.271125] dwc2 ff540000.usb: ff540000.usb supply vusb_d not found, using dummy regulator
[ 1.280476] dwc2 ff540000.usb: ff540000.usb supply vusb_a not found, using dummy regulator
[ 1.425273] dwc2 ff540000.usb: DWC OTG Controller
[ 1.430578] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
[ 1.438536] dwc2 ff540000.usb: irq 45, io mem 0xff540000
[ 1.445405] hub 1-0:1.0: USB hub found
[ 1.449660] hub 1-0:1.0: 1 port detected
[ 1.454580] dwc2 ff580000.usb: ff580000.usb supply vusb_d not found, using dummy regulator
[ 1.463963] dwc2 ff580000.usb: ff580000.usb supply vusb_a not found, using dummy regulator
[ 1.835131] dwc2 ff580000.usb: dwc2_check_param_tx_fifo_sizes: Invalid parameter g-tx-fifo-size, setting to default average
[ 1.847665] dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 1.856108] dwc2 ff580000.usb: DWC OTG Controller
[ 1.861409] dwc2 ff580000.usb: new USB bus registered, assigned bus number 2
[ 1.869363] dwc2 ff580000.usb: irq 46, io mem 0xff580000
[ 1.876126] hub 2-0:1.0: USB hub found
[ 1.880381] hub 2-0:1.0: 1 port detected
[ 1.885955] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.893274] ehci-pci: EHCI PCI platform driver
[ 1.898339] ehci-platform: EHCI generic platform driver
[ 1.904465] ehci-orion: EHCI orion driver
[ 1.909191] SPEAr-ehci: EHCI SPEAr driver
[ 1.913865] ehci-st: EHCI STMicroelectronics driver
[ 1.919541] ehci-exynos: EHCI EXYNOS driver
[ 1.924442] ehci-atmel: EHCI Atmel driver
[ 1.929134] tegra-ehci: Tegra EHCI driver
[ 1.933844] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.940801] ohci-pci: OHCI PCI platform driver
[ 1.945855] ohci-platform: OHCI generic platform driver
[ 1.951929] ohci-omap3: OHCI OMAP3 driver
[ 1.956638] SPEAr-ohci: OHCI SPEAr driver
[ 1.961321] ohci-st: OHCI STMicroelectronics driver
[ 1.966982] ohci-atmel: OHCI Atmel driver
[ 1.972467] usbcore: registered new interface driver usb-storage
[ 1.984909] i2c /dev entries driver
[ 1.991098] rk3x-i2c ff140000.i2c: Initialized RK3xxx I2C bus at f0a87000
[ 1.999419] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at f0a89000
[ 2.007725] rk3x-i2c ff170000.i2c: Initialized RK3xxx I2C bus at f0a8b000
[ 2.016601] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 2.024370] fan53555-reg: supplied by vcc_sys
[ 2.031647] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 2.039439] fan53555-reg: supplied by vcc_sys
[ 2.046352] REG1: supplied by vcc_sys
[ 2.051397] REG2: supplied by vcc_sys
[ 2.056435] REG3: supplied by vcc_sys
[ 2.061423] REG4: supplied by vcc_sys
[ 2.066476] REG5: supplied by vcc_sys
[ 2.071463] REG6: supplied by vcc_sys
[ 2.076533] REG7: supplied by vcc_sys
[ 2.080965] vcca_18: Bringing 3300000uV into 1800000-1800000uV
[ 2.088643] REG8: supplied by vcc_sys
[ 2.093496] REG9: supplied by vcc_sys
[ 2.098403] REG10: supplied by vcc_20
[ 2.103526] REG11: supplied by vcc_20
[ 2.108710] REG12: supplied by vcc_20
[ 2.113861] rk3x-i2c ff650000.i2c: Initialized RK3xxx I2C bus at f0a8d000
[ 2.122145] rk3x-i2c ff660000.i2c: Initialized RK3xxx I2C bus at f0a8f000
[ 2.133292] vcc28_dvp: supplied by vcc_io
[ 2.138007] dovdd_1v8: supplied by vcc28_dvp
[ 2.142948] vcc_flash: supplied by vcc_io
[ 2.154119] rockchip-thermal ff280000.tsadc: Missing rockchip,grf property
[ 2.168595] random: fast init done
[ 2.173786] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 500000 KHz
[ 2.182278] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 600000 KHz
[ 2.194175] sdhci: Secure Digital Host Controller Interface driver
[ 2.201093] sdhci: Copyright(c) Pierre Ossman
[ 2.206578] Synopsys Designware Multimedia Card Interface Driver
[ 2.213759] dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.221880] dwmmc_rockchip ff0c0000.dwmmc: Using internal DMA controller.
[ 2.229476] dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a
[ 2.235917] dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 30,32 bit host data width,256 deep fifo
[ 2.246841] vcc_sd: supplied by vcc_io
[ 2.395118] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.435129] dwmmc_rockchip ff0c0000.dwmmc: 1 slots initialized
[ 2.443100] dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.451257] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller.
[ 2.458880] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a
[ 2.465365] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 31,32 bit host data width,256 deep fifo
[ 2.477491] dwmmc_rockchip ff0d0000.dwmmc: Failed getting OCR mask: 0
[ 2.484717] mmc_host mmc1: card is non-removable.
[ 2.490061] dwmmc_rockchip ff0d0000.dwmmc: could not set regulator OCR (-22)
[ 2.497967] dwmmc_rockchip ff0d0000.dwmmc: failed to enable vmmc regulator
[ 2.535127] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.575265] dwmmc_rockchip ff0d0000.dwmmc: 1 slots initialized
[ 2.582266] dwmmc_rockchip ff0f0000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.590475] dwmmc_rockchip ff0f0000.dwmmc: Using internal DMA controller.
[ 2.598105] dwmmc_rockchip ff0f0000.dwmmc: Version ID is 270a
[ 2.604567] dwmmc_rockchip ff0f0000.dwmmc: DW MMC controller at irq 32,32 bit host data width,256 deep fifo
[ 2.615846] mmc_host mmc2: card is non-removable.
[ 2.633593] dwmmc_rockchip ff0d0000.dwmmc: could not set regulator OCR (-22)
[ 2.641505] dwmmc_rockchip ff0d0000.dwmmc: failed to enable vmmc regulator
[ 2.649277] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.685118] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 2.695606] dwmmc_rockchip ff0f0000.dwmmc: 1 slots initialized
[ 2.702894] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.711614] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.718620] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.724780] usbcore: registered new interface driver usbhid
[ 2.731041] usbhid: USB HID core driver
[ 2.737166] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.744225] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.750441] NET: Registered protocol family 10
[ 2.755836] Segment Routing with IPv6
[ 2.759971] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.766881] NET: Registered protocol family 17
[ 2.771863] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.786367] can: controller area network core (rev 20170425 abi 9)
[ 2.793300] NET: Registered protocol family 29
[ 2.798273] can: raw protocol (rev 20170425)
[ 2.803044] can: broadcast manager protocol (rev 20170425 t)
[ 2.809378] can: netlink gateway (rev 20170425) max_hops=1
[ 2.815694] Key type dns_resolver registered
[ 2.820557] ThumbEE CPU extension supported.
[ 2.825341] Registering SWP/SWPB emulation handler
[ 2.836282] rk_gmac-dwmac ff290000.ethernet: PTP uses main clock
[ 2.843041] rk_gmac-dwmac ff290000.ethernet: clock input or output? (input).
[ 2.848327] dwmmc_rockchip ff0d0000.dwmmc: could not set regulator OCR (-22)
[ 2.848330] dwmmc_rockchip ff0d0000.dwmmc: failed to enable vmmc regulator
[ 2.866502] rk_gmac-dwmac ff290000.ethernet: TX delay(0x30).
[ 2.872827] rk_gmac-dwmac ff290000.ethernet: RX delay(0x10).
[ 2.875101] mmc_host mmc1: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 2.878945] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
[ 2.879050] mmc2: new high speed MMC card at address 0001
[ 2.879272] mmcblk2: mmc2:0001 8GTF4R 7.28 GiB
[ 2.879351] mmcblk2boot0: mmc2:0001 8GTF4R partition 1 4.00 MiB
[ 2.879428] mmcblk2boot1: mmc2:0001 8GTF4R partition 2 4.00 MiB
[ 2.879498] mmcblk2rpmb: mmc2:0001 8GTF4R partition 3 512 KiB
[ 2.890370] mmcblk2: p1 p2 p3 p4 < p5 p6 >
[ 2.935835] rk_gmac-dwmac ff290000.ethernet: clock input from PHY
[ 2.938777] dwmmc_rockchip ff0d0000.dwmmc: could not set regulator OCR (-22)
[ 2.938780] dwmmc_rockchip ff0d0000.dwmmc: failed to enable vmmc regulator
[ 2.963212] rk_gmac-dwmac ff290000.ethernet: init for RGMII
[ 2.969588] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 2.975102] mmc_host mmc1: Bus speed (slot 0) = 187500Hz (slot req 100000Hz, actual 93750HZ div = 1)
[ 2.985463] rk_gmac-dwmac ff290000.ethernet: Ring mode enabled
[ 2.991981] rk_gmac-dwmac ff290000.ethernet: DMA HW capability register supported
[ 3.000353] rk_gmac-dwmac ff290000.ethernet: Normal descriptors
[ 3.006974] rk_gmac-dwmac ff290000.ethernet: RX Checksum Offload Engine supported
[ 3.015345] rk_gmac-dwmac ff290000.ethernet: COE Type 2
[ 3.021183] rk_gmac-dwmac ff290000.ethernet: TX Checksum insertion supported
[ 3.029065] rk_gmac-dwmac ff290000.ethernet: Wake-Up On Lan supported
[ 3.036277] rk_gmac-dwmac ff290000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 4.199912] libphy: stmmac: probed
[ 4.203866] rk_gmac-dwmac ff290000.ethernet (unnamed net_device) (uninitialized): PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 4.217467] rk_gmac-dwmac ff290000.ethernet (unnamed net_device) (uninitialized): PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 4.235948] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 4.245039] hctosys: unable to open rtc device (rtc0)
[ 4.251138] dovdd_1v8: disabling
[ 4.254751] vcc_sd: disabling
[ 4.258607] ttyS2 - failed to request DMA
[ 4.270405] Freeing unused kernel memory: 9216K
starting version 237
[ 4.858910] CP437: Invalid argument
[ 4.873801] fsck.fat 4.1 (2017-01-24)
[ 4.873801] /dev/disk/by-label/resin-boot: 15 files, 6060/20431 clusters
[ 4.891507] resin-rootA: recovering journal
[ 4.901344] resin-rootA: clean, 4461/39936 files, 222825/319488 blocks
[ 4.901351]
[ 4.931350] resin-rootB: clean, 11/39936 files, 15349/319488 blocks
[ 4.931358]
[ 4.950309] resin-state: recovering journal
[ 4.980240] resin-state: clean, 12/5136 files, 1850/20480 blocks
[ 4.980252]
[ 5.169610] mmcblk2: p1 p2 p3 p4 < p5 p6 >
[ 6.339962] EXT4-fs (mmcblk2p2): mounted filesystem with ordered data mode. Opts: (null)
[ 6.370905] EXT4-fs (mmcblk2p5): mounted filesystem with ordered data mode. Opts: (null)
[ 6.622965] EXT4-fs (mmcblk2p2): re-mounted. Opts: (null)
[ 6.828618] systemd[1]: System time before build time, advancing clock.
[ 6.846189] cgroup: cgroup2: unknown option "nsdelegate"
[ 6.864086] systemd[1]: systemd 237 running in system mode. (-PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 6.888996] systemd[1]: Detected architecture arm.
Welcome to balenaOS 2.38.3+rev7!
[ 6.925401] systemd[1]: No hostname configured.
[ 6.930487] systemd[1]: Set hostname to <localhost>.
[ 6.940056] systemd[1]:
DRAM: 2 GiB
In: serial
