Is it possible to flash Nvidia Jetsons using USB cables based on a Yocto (meta-tegra) distribution with the BalenaEtcher Pro system ?
Best regards
Best regards
Hi @austriker, balenaEtcherPro is using the free and open-source balenaEtcher software which is cross platform. To check whether a setup is supported by EtcherPro you can download Etcher and test it on your system. In this case, Nvidia Jetson is not yet supported to flash directly but we are working on it and it’ll be available in the following months.
