[My screen does not recognize the flashed sd card]
hello,
I flashed my sd card using sd adapter with balena etcher,
The card was successfully flashed, and when I plug the sd card into my Jetson nano which is connected to a keyboard display.
My screen freezes and displays Nvidia for 6 hours
I have the impression that the map of my screen does not recognize the flashed sd card
Please help me
Did you follow the instructions you can see on the right?
In balenaCloud, you can “Add Device”, and select the Jetson Nano SD-Card (that particular device type is the 4gb model…we use 2gb in the naming convention for the 2gb version).
Just be sure to look close at the instructions in the Pop-up Modal on the page, you have to use the “jetson-flash” utility to directly write the image to the board (with SD Card inserted) via Recovery mode.
