I would like to change the tohora UI, I saw inside the BalenaDash Project on RPI4 (64bit).
# build tohora from source
FROM balenalib/raspberrypi3-golang as builder
RUN go get -d -v github.com/mozz100/tohora/...
WORKDIR /go/src/github.com/mozz100/tohora
RUN go build
I downloaded the Github repo and changed the HTML files inside and stored all folder as tohora folder inside my kiosk folder.
Now inside Dockerfile.raspberry4-64.template
build tohora from source (replace the one above)
COPY ./tohora ./tohora
WORKDIR /tohora
RUN go build
I wanted to do this and build it without having to go get from the Github.
When building it I get following error:
What is the correct path, I have to set in the Dockerfile? Thanks
