I’ve inherited a legacy app that compiles Tohora from source at the start of the Dockerfile i.e.
# build tohora from source
FROM balenalib/raspberrypi3-golang as builder
RUN go get -d -v github.com/mozz100/tohora/...
WORKDIR /go/src/github.com/mozz100/tohora
RUN go build
When I try to use balena push to deploy the code to my test device I get the following error,
[main] Step 1/33 : FROM balenalib/raspberrypi3-golang as builder
[main] ---> 448bfdca5029
[main] Step 2/33 : RUN go get -d -v github.com/mozz100/tohora/...
[main] Using cache
[main] ---> a4654c443c8f
[main] Step 3/33 : WORKDIR /go/src/github.com/mozz100/tohora
[main] Using cache
[main] ---> 10c44ea6653f
[main] Step 4/33 : RUN go build
[main] ---> Running in 164be2f108cf
[main] go: go.mod file not found in current directory or any parent directory; see 'go help modules'
[main]
[main] Removing intermediate container 164be2f108cf
[main] The command '/bin/sh -c go build' returned a non-zero code: 1
This code was deployed to other production devices and is still running on them fine. I can also run the Docker build locally too with no problems and everything just builds. Can anyone suggest why the code won’t deploy here? Should I be using a different method such as git push or something?
