USB Boot Installer running fine until “Failed to start Resin init flasher service.” “See ‘systemctl status resin-init-flasher.service’ for details.” I was following the recommendation to add app/device as Intel NUC (v2.31.2+rev1). Hardware is technically “VIA Eden X2 U4200 (1 GHz, 2 cores)” but HP states it is fully x86 compatible. Should this work? Recommendations?
