I’m on the “Preparing the balenaFin” section of Getting Started.
I just got the dev kit a few moments ago and started following the instructions.
CM3 is seated well.
Connected PRG to MacBookPro.
Balena Etcher just sits at Initializing Device (image attached). The progress bar filled for an instant and then went back to ~1/5 full. Been there for 20 minutes.
Hi @kijana.woodard ! You need balenaEtcher 1.5.0 or newer in order to be able to flash the Raspberry Compute Module 3+ Lite that comes in the balenaFin v1.1 devkit - can you please check what version of etcher you are running?
