Doesn't seem to finish flashing, no error
So I downloaded the Etcher fine, and tried flashing kali linux live iso to a USB drive. But after I selected “Flash”, and entered my password, it just brought me back immediately to the normal interface. (also, I forgot to check the logs, sorry bout that.) It didn’t give me the “Success!” screen or whatever. What did I do wrong?
I’m on mac v. 11.6
Hello @zanelien welcome to the balena forums. Sorry to hear that it didn’t work.
Could you please share the logs pressing Shift + Command + i? What etcher version are you using?
Thanks, this is the entire console output:
index.css:1 Failed to load resource: net::ERR_FILE_NOT_FOUND
electron/js2c/renderer_init.js:13 (electron) The remote module is deprecated. Use https://github.com/electron/remote instead.
log @ electron/js2c/renderer_init.js:13
gui.js:90465  _____ _       _
|  ___| |     | |
| |__ | |_ ___| |__   ___ _ __
|  __|| __/ __| '_ \ / _ \ '__|
| |___| || (__| | | |  __/ |
\____/ \__\___|_| |_|\___|_|
Interested in joining the Etcher team?
Drop us a line at join+etcher@balena.io
Version = 1.5.122, Type = dmg
gui.js:58408 Thu Sep 16 2021 16:19:10 GMT-0700 (Pacific Daylight Time) Application start ({"packageType":"dmg","version":"1.5.122","sample":0.1,"applicationSessionUuid":"c2029eb0-b79e-4a63-a116-9b2d6945dba8","flashingWorkflowUuid":"1c7229cc-515f-439a-9a67-68f693f4f201"})
gui.js:51110 Thu Sep 16 2021 16:19:11 GMT-0700 (Pacific Daylight Time) Open image selector ({"sample":0.1,"applicationSessionUuid":"c2029eb0-b79e-4a63-a116-9b2d6945dba8","flashingWorkflowUuid":"1c7229cc-515f-439a-9a67-68f693f4f201"})
gui.js:51110 Thu Sep 16 2021 16:19:14 GMT-0700 (Pacific Daylight Time) Image selector closed ({"sample":0.1,"applicationSessionUuid":"c2029eb0-b79e-4a63-a116-9b2d6945dba8","flashingWorkflowUuid":"1c7229cc-515f-439a-9a67-68f693f4f201"})
gui.js:51110 Thu Sep 16 2021 16:19:24 GMT-0700 (Pacific Daylight Time) Open image selector ({"sample":0.1,"applicationSessionUuid":"c2029eb0-b79e-4a63-a116-9b2d6945dba8","flashingWorkflowUuid":"1c7229cc-515f-439a-9a67-68f693f4f201"})
gui.js:51110 Thu Sep 16 2021 16:19:46 GMT-0700 (Pacific Daylight Time) Select image ({"image":{"size":3215994880,"name":"kali-linux-2021.2-live-i386.iso","hasMBR":true,"partitions":[{"offset":32768,"size":3214901248,"type":23,"index":1},{"offset":3214934016,"size":753664,"type":1,"index":2}],"extension":"iso","path":"/Users/zanehemphill/Downloads/kali-linux-2021.2-live-i386.iso","logo":false,"blockMap":false},"sample":0.1,"applicationSessionUuid":"c2029eb0-b79e-4a63-a116-9b2d6945dba8","flashingWorkflowUuid":"1c7229cc-515f-439a-9a67-68f693f4f201"})
gui.js:51110 Thu Sep 16 2021 16:19:54 GMT-0700 (Pacific Daylight Time) Flash ({"image":{"size":3215994880,"name":"kali-linux-2021.2-live-i386.iso","hasMBR":true,"partitions":[{"offset":32768,"size":3214901248,"type":23,"index":1},{"offset":3214934016,"size":753664,"type":1,"index":2}],"extension":"iso","path":"/Users/zanehemphill/Downloads/kali-linux-2021.2-live-i386.iso"},"drives":[{"size":16018046976,"isVirtual":false,"enumerator":"DiskArbitration","logicalBlockSize":512,"raw":"/dev/rdisk2","error":null,"isReadOnly":false,"displayName":"/dev/disk2","blockSize":512,"isSCSI":false,"isRemovable":true,"device":"/dev/disk2","busVersion":null,"isSystem":false,"busType":"USB","isCard":false,"isUSB":true,"devicePath":"IODeviceTree:/PCI0@0/XHC1@14","mountpoints":[{"path":"/Volumes/LEXAR","label":"LEXAR"}],"description":"Lexar USB Flash Drive Media","isUAS":null,"partitionTableType":"mbr"}],"driveCount":1,"uuid":"465496e2-9c7e-4a36-a3fe-5bf4d86ea443","status":"started","flashInstanceUuid":"465496e2-9c7e-4a36-a3fe-5bf4d86ea443","sample":0.1,"applicationSessionUuid":"c2029eb0-b79e-4a63-a116-9b2d6945dba8","flashingWorkflowUuid":"1c7229cc-515f-439a-9a67-68f693f4f201"})
gui.js:51110 Elevating command: /private/var/folders/73/vrkmbjc16q73721vyqdrt4_00000gq/T/AppTranslocation/8A438E1F-24A5-4BFD-8935-46DCF38C2F0D/d/balenaEtcher.app/Contents/Frameworks/balenaEtcher Helper (Renderer).app/Contents/MacOS/balenaEtcher Helper (Renderer) /private/var/folders/73/vrkmbjc16q73721vyqdrt4_00000gq/T/AppTranslocation/8A438E1F-24A5-4BFD-8935-46DCF38C2F0D/d/balenaEtcher.app/Contents/Resources/app/generated/child-writer.js
gui.js:38454  0 devices, 0% at 0.00 MB/s (total 0.00 MB/s)  with 0 failed devices
gui.js:51110 Thu Sep 16 2021 16:19:56 GMT-0700 (Pacific Daylight Time) SafeWebview loaded ({"event":{"id":1,"url":"https://assets.balena.io/etcher-featured/index.html?borderRight=false&darkBackground=true&etcher-version=1.5.122&api-version=2&optOutAnalytics=false","method":"GET","timestamp":1631834395189.461,"resourceType":"mainFrame","ip":"172.67.149.103","fromCache":false,"statusLine":"HTTP/1.1 200","statusCode":200,"responseHeaders":{"access-control-allow-origin":["*"],"age":["560"],"alt-svc":["h3=\":443\"; ma=86400, h3-29=\":443\"; ma=86400, h3-28=\":443\"; ma=86400, h3-27=\":443\"; ma=86400"],"cache-control":["max-age=600"],"cf-cache-status":["DYNAMIC"],"cf-ray":["68fdd28a2cf9deed-SEA"],"content-encoding":["br"],"content-type":["text/html; charset=utf-8"],"date":["Thu, 16 Sep 2021 23:19:55 GMT"],"expect-ct":["max-age=604800, report-uri=\"https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct\""],"expires":["Wed, 15 Sep 2021 03:43:57 GMT"],"last-modified":["Tue, 14 Sep 2021 17:43:25 GMT"],"nel":["{\"success_fraction\":0,\"report_to\":\"cf-nel\",\"max_age\":604800}"],"report-to":["{\"endpoints\":[{\"url\":\"https:\\/\\/a.nel.cloudflare.com\\/report\\/v3?s=9KEjNB%2BJW2DOjH4QYhRAJ3R5vbJOg1h00hFwzyn%2FrgYyAT16q%2BDt2TYmSQXrDuEhJd0CBW6wBrsnVkYjRz0KFqqzhX2M6zEl9ZLdm6v3L1vyCtwExNth2PJtG685ztMjNqR3\"}],\"group\":\"cf-nel\",\"max_age\":604800}"],"server":["cloudflare"],"vary":["Accept-Encoding"],"via":["1.1 varnish"],"x-cache":["HIT"],"x-cache-hits":["1"],"x-fastly-request-id":["bfb6700d9fb5b64364626e6eafa87930cbbe1564"],"x-github-request-id":["269C:0B3A:B4B953:1534226:614169A5"],"x-origin-cache":["HIT"],"x-proxy-cache":["MISS"],"x-served-by":["cache-sea4468-SEA"],"x-timer":["S1631834395.232111,VS0,VE1"]},"referrer":"","error":"net::OK"},"sample":0.1,"applicationSessionUuid":"c2029eb0-b79e-4a63-a116-9b2d6945dba8","flashingWorkflowUuid":"1c7229cc-515f-439a-9a67-68f693f4f201"})
gui.js:51110 Terminating IPC server
gui.js:51110 Flash results {cancelled: true, skip: false}
gui.js:51110 Thu Sep 16 2021 16:20:11 GMT-0700 (Pacific Daylight Time) Elevation cancelled ({"image":{"size":3215994880,"name":"kali-linux-2021.2-live-i386.iso","hasMBR":true,"partitions":[{"offset":32768,"size":3214901248,"type":23,"index":1},{"offset":3214934016,"size":753664,"type":1,"index":2}],"extension":"iso","path":"/Users/zanehemphill/Downloads/kali-linux-2021.2-live-i386.iso"},"drives":[{"size":16018046976,"isVirtual":false,"enumerator":"DiskArbitration","logicalBlockSize":512,"raw":"/dev/rdisk2","error":null,"isReadOnly":false,"displayName":"/dev/disk2","blockSize":512,"isSCSI":false,"isRemovable":true,"device":"/dev/disk2","busVersion":null,"isSystem":false,"busType":"USB","isCard":false,"isUSB":true,"devicePath":"IODeviceTree:/PCI0@0/XHC1@14","mountpoints":[{"path":"/Volumes/LEXAR","label":"LEXAR"}],"description":"Lexar USB Flash Drive Media","isUAS":null,"partitionTableType":"mbr"}],"driveCount":1,"uuid":"465496e2-9c7e-4a36-a3fe-5bf4d86ea443","status":"cancel","flashInstanceUuid":"465496e2-9c7e-4a36-a3fe-5bf4d86ea443","sample":0.1,"applicationSessionUuid":"c2029eb0-b79e-4a63-a116-9b2d6945dba8","flashingWorkflowUuid":"1c7229cc-515f-439a-9a67-68f693f4f201"})
Hello @zanelien, thank you for the information. Judging from the error log Elevation cancelled, seems like you are experiencing an issue we observed on MacOS earlier:
As noted in the GitHub issue, until we implemented a different solution, the workaround is to run the Etcher app with sudo. Can you please try that and note how it goes?
Cheers…
