Balena Etcher essentially killed my USB.
after i tried to flash my kingston usb with Ubuntu, the usb doesn’t show up anymore in explorer.
whenever i try to delete the partition of the usb in disk management, it throws an error “the request is not supported”.
when i try to format it, gives me another error: “Windows cannot format the volume because the volume is offline. Please try to online the volume by assigning a drive letter or path to the volume first.”
i tried to use diskpart to use the “clean” command, but that throws the same error as the one when i try to delete it in disk management.
converting it to gpt or mbr also doesnt work, and gives me the same error.
please help.
i still did not get a reply. i haven’t fixed the issue yet. help me, please.
