I followed this official tutorial to set up openBalena.
The only thing I did differently was to include the -c flag to the ./scripts/quickstart command as it was suggested in the official screencast. Everything worked fine and I am able to add apps and devices to the system (this means that balena apps and balena devices commands work flawlessl.
However, when I try to push a new image to the app and execute balena deploy <appName>, I get the following error:
Retrying "registry.balena.mydomain.ee/v2/<token>:latest" after 2.00s (1 of 3) due to: Error: unauthorized: authentication required
Retrying "registry.balena.mydomain.ee/v2/<token>:latest" after 2.80s (2 of 3) due to: Error: unauthorized: authentication required
[Info] Saving release...
[Error] Deploy failed
How can I fix this issue?
Are there any workarounds?
Thank you for your quick response!
I am using Balena CLI version 12.26.2 and openBalena version 3.1.0.
I logged in with balena login using the Credentials options.
Juhhu! I finally got it working.
I started from the very beginning with a fresh machine and strictly followed the tutorial. In particular compared to the previous attempt:
I did not use the -c flag for ./scripts/quickstart
I installed docker.io a shown in the tutorial (previously I used a version of Docker CE which was automatically installed by DigitalOcean)
Thank you for your quick responses! I must say I really love the developer experience of working with Balena (both cloud and open versions). Also, your open-source friendly business model is very inspiring for us and we want to have a similar policy with our own solutions as well.
I am experiencing the same error… I am a openbalena v2.0.0 user and I recently update the root/vpn certificates through re-running the quickstart script on my server
I am using the balena.-cli version:
balena --version
12.2.2
I get this error while trying to deploy an application:
DEBUG=1 balena deploy myApp
I got this error:
[debug] original argv0="/usr/local/lib/balena-cli/bin/node" argv=[/usr/local/lib/balena-cli/bin/node,/usr/local/lib/balena-cli/bin/run,deploy,myApp] length=4
[Debug] Parsing input...
(node:97932) ExperimentalWarning: The fs.promises API is experimental
[Debug] Loading project...
[Debug] Resolving project...
[Debug] docker-compose.yml file found at "/Users/matteo/Desktop/iottacle/balenaApp/myApp"
[Debug] Creating project...
[Info] Everything is up to date (use --build to force a rebuild)
[Info] Creating release...
[Debug] Tagging images...
[Debug] Authorizing push...
[Info] Pushing images to registry...
Retrying "registry.mydomain.com/v2/token:latest" after 2.00s (1 of 3) due to: Error: unauthorized: authentication required
Retrying "registry.mydomain.com/v2/token:latest" after 2.80s (2 of 3) due to: Error: unauthorized: authentication required
Retrying "registry.mydomain.com/v2/token:latest" after 3.92s (3 of 3) due to: Error: unauthorized: authentication required
[Debug] Saving image registry.mydomain.com/v2/token
[Debug] Untagging images...
at Stream.<anonymous> (/usr/local/lib/balena-cli/node_modules/docker-progress/index.js:53:19)
at Stream.emit (events.js:198:13)
at Stream.EventEmitter.emit (domain.js:448:20)
at drain (/usr/local/lib/balena-cli/node_modules/through/index.js:36:16)
at Stream.stream.queue.stream.push (/usr/local/lib/balena-cli/node_modules/through/index.js:45:5)
at Parser.parser.onToken (/usr/local/lib/balena-cli/node_modules/JSONStream/index.js:132:18)
at Parser.proto.write (/usr/local/lib/balena-cli/node_modules/jsonparse/jsonparse.js:135:34)
at Stream.<anonymous> (/usr/local/lib/balena-cli/node_modules/JSONStream/index.js:23:12)
at Stream.stream.write (/usr/local/lib/balena-cli/node_modules/through/index.js:26:11)
at IncomingMessage.ondata (_stream_readable.js:693:20)
at IncomingMessage.emit (events.js:198:13)
at IncomingMessage.EventEmitter.emit (domain.js:448:20)
at addChunk (_stream_readable.js:288:12)
at readableAddChunk (_stream_readable.js:269:11)
at IncomingMessage.Readable.push (_stream_readable.js:224:10)
at HTTPParser.parserOnBody (_http_common.js:122:22)
at awaitRegistryStream (/usr/local/lib/balena-cli/node_modules/docker-progress/index.js:43:12)
at /usr/local/lib/balena-cli/node_modules/docker-progress/index.js:416:16
at runCallback (timers.js:705:18)
at tryOnImmediate (timers.js:676:5)
at processImmediate (timers.js:658:5)
at process.topLevelDomainCallback (domain.js:126:23)
at DockerProgress.exports.DockerProgress.DockerProgress.push (/usr/local/lib/balena-cli/node_modules/docker-progress/index.js:415:56)
at Bluebird.join.retry (/usr/local/lib/balena-cli/build/utils/compose.js:499:197)
at retry (/usr/local/lib/balena-cli/build/utils/helpers.js:111:31)
at Bluebird.delay.then (/usr/local/lib/balena-cli/build/utils/helpers.js:116:53)
at ontimeout (timers.js:436:11)
at tryOnTimeout (timers.js:300:5)
at listOnTimeout (timers.js:263:5)
at Timer.processTimers (timers.js:223:10)
From previous event:
at runCommand (/usr/local/lib/balena-cli/build/app-capitano.js:57:20)
at Object.run (/usr/local/lib/balena-cli/build/app-capitano.js:67:42)
at routeCliFramework (/usr/local/lib/balena-cli/build/preparser.js:44:79)
at process._tickCallback (internal/process/next_tick.js:68:7)
at Function.Module.runMain (internal/modules/cjs/loader.js:832:11)
at startup (internal/bootstrap/node.js:283:19)
at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
I went on the server on the registry container and I found this error:
Hey matteopeluso
I found this question that’s been unanswered for nearly two months now… It must have got stuck at the bottom
I hope you did manage to sort out the issue.
For what it’s worth, I’ve noticed two things:
1st, the log is saying that you are using the mydomain.com. You should replace in the instructions this with your own domain
2nd, since you are already using openBalena, you should also update the devices’ certificates so they can in fact be authorised
