One of my app keep failing to update.
I’ve tried to redeploy multiple times and I keep having the following error.
Failed to download application 'registry2.resin.io/xxxxxxxxx' due to 'rsync exited. code: 12 signal: null'
Hello there – disabling deltas, letting the device pull the update and re-enabling deltas afterwards should fix the issue.
However I wonder how this happened – what versions (resinOS/Supervisor) is this device on, was this a large update, and do you remember doing something out of the ordinary when this happened?
I had this issue today as well on Resin OS 2.3.0+rev1 (dev).
I’m working on another update and will see if a further commit generating a new delta will resolve the issue.
I can confirm that pushing another update didn’t fix the issue.
Had another issue with updates too on 1/3 devices on a delta update. A full update worked fine though.
22.12.17 23:04:51 (+1100) Failed to download application 'registry2.resin.io/test**/**' due to 'Incompatible image'
How is that even possible? All the devices are the same…
